54 Chevy Lowering Question
Discussion in 'The Hokey Ass Message Board' started by adamshumard, Jan 16, 2009.
  1. adamshumard
    adamshumard
    Whats the best way to lower a 54 chevy 210 in the front without going mustangII or stubing it? Are there drop spindles out there? Based on the height of my car, cut springs would cause camber to be something horrible. Any help would be great.
  2. TexasHardcore
    TexasHardcore
    from Austin-ish
    I cut springs in 4 of these cars already. 1.5 springs out and it sits fine, and drives nice. There are dropped uprights available as well, or you can bag the stock front suspension with some mild fabrication.
    Here's ours with 1.5 coils cut up front....
  3. alex1954chevy
    alex1954chevy
    I CUT 3 coils off mine and it rides pretty good. but the best thing to do is bag it.
  4. rustypipes
    rustypipes
    from san jose
  5. smith32
    smith32
    we cut the coils on the 53 that my boy use to own and it rode pretty good...seems to me like i remember him saying that chassis engineering sold the dropped uprights but really cant remember
    check 50chevy.com they have some very useful tech stuff in there
  6. Big Tony
    Big Tony
    Gambino drop spindles and cut a coil to coil and a half and she will get down there for you and still have room for alignment and ride. Any lower in the front and you will have to atleast notch the rear to get it sitting right
  7. Big Jon
    Big Jon
    how much did it drop by taking a coil and a half out ?
    JD
  8. 302GMC
    302GMC
    from Idaho
    1 coil is 2''-3'' ... 2 coils is 3''-4''. That's with tired springs ...
  9. TexasHardcore
    TexasHardcore
    from Austin-ish
    I forgot to mention my car, as pictured above, has a small block and automatic. The extra weight brings the car down even more.
  10. In addition to the already mentioned options you can also step the lower A-arms. Ther was an EXCELLENT tech posting on it a couple of weeks ago. it will probalby give you another 2" of drop along with the other mods. Todd
  11. Frank32
    Frank32
    I used Fatman Fabrication dropped spindles in the front of this 1950 Chevy, without cutting any colis. The ride was great.
  12. nexxussian
    nexxussian
    Bufalo Engineering makes a set of lowering uprights that are set up to give a few degrees more caster too.
    Wasn't there a thread on here about NAPA front springs for a minivan or something that worked to lower these as well?
  13. Jalopy Joker
    Jalopy Joker
    Plus, you can do a search here on this topic-lots of info already posted.
  14. adamshumard
    adamshumard
    how close can you get the car to the ground with out notching the rear?
  15. wvenfield
    wvenfield
    The problem you get before having to worry about notching is the enclosed drive shaft. You'll have to change that out before worrying about notching.
  16. Any more pics of this car?
  17. adamshumard
    adamshumard
    If I keep the enclosed drive shaft, how low can I go in the rear? What size drop blocks?
  18. Jalopy Joker
    Jalopy Joker
    adamshumard: Stop asking, and start seaching this site for your answers.
  19. adamshumard
    adamshumard
    I looked, didn't find what i wanted to know. excuse me.
  20. inliner54
    inliner54
    I put dearched 4 inch drop leafs in rear with A Gambino Customs c-notch kit and custom 4 inch blocks that cost me about $500 in parts to do the rear for 8 inches of drop. in the front Flipped spindles that were cut in half and welded 3 inches higher using a total of 4 spindles to make them work, then 2 coils were removed and dropped steering arms also that cost $300 used but RM engineering in PDX, OR can do this for you if you can't. It is the old school way of doing it right. P.S. my car is lower now than in the pic to the left.
  21. Pistnbroke
    Pistnbroke
    2 1/5 coils cut out of the front and c-notched the rear with 4 inch blocks and 3 leafs removed, we use air shocks to help the rear with a full loaded car. Drives nice and handles fine.
  22. NCrod
    NCrod
    I cut about 2 coils off the front and for the rear i dearched the main spring and flipped the eyes . No problems for me and the ride is great.
  23. Frank32
    Frank32
    Here are a few more pics
  24. FUCK..... sweet looking car!!!!!
  25. wvenfield
    wvenfield
    There are tons of info here already on doing this but sometimes it can be hard to find the correct search words to bring it up.
    Do some different searches. They have to bring up all sorts of information. This has been covered in depths many times here.
  26. Very nice. Thanks for the pics.
  27. adamshumard
    adamshumard
    I tried a few more searches after that and did find more info. I think the cheap answer here is 4 inch blocks, 3 coils and hit the road.
  28. cretin
    cretin
    This is the stepping the lower A arms post. He says you get 2 1/2" of drop from this.
    http://www.jalopyjournal.com/forum/showthread.php?t=317696
    On mine I have dropped uprights, steering arms, and bags
  29. Hot Rod Michelle
    Hot Rod Michelle
    Does Gambino make drop spindles for '48 Chevy's?
  30. cretin
    cretin
    I think he sells them. Shoot him a PM
