54 chevy master cylinder upgrade?
Discussion in 'The Hokey Ass Message Board' started by panheadgeorge, Jun 18, 2007.
  1. panheadgeorge
    panheadgeorge
    Hi, Guy's I was wondering if anybody out there had any recomendations on up grading to a dual M/C on a 54 chevy with stickshift trans,( so the pedal's are on the same axis.) Is there a mount available to mount a drum/drum truck or corvette M/C that anybody knows of?
  2. Several folks make a mount; it amounts to a bracket and an extra long rod, through the old master into a new one. You can make it yourself if the kits are too expensive. '68 Chevelle manual drum master works, $20 at any parts store.
    You can also put it on the firewall with an S10 or 55-60 Chevy hanging pedal bracket. Just drill the holes and bolt it up.
  3. 53sled
    53sled
    from KCMO
    filling station dot com search through the master cylinder options, another guy out of florida makes a piece that you thread onto the end, then bolt a master to it.
  4. panheadgeorge
    panheadgeorge
    Thanks Alot for the info....Guy's I found what I was looking for Through the filling station....a little pricey but bolts in stock location.
    Thanks again!!!!
