Technical 54 Chevy part identification?
Discussion in 'The Hokey Ass Message Board' started by Chris-Bartlett, Sep 6, 2017.
  1. Chris-Bartlett
    Chris-Bartlett
    I'm trying to identify this part to replace it since mine broke. I don't know if it's called a "perch," but that doesn't help me find the part in searches.
    It's the part that is attached to the axle with a bushing and is supposed to rest flat on the leaf springs (or in my case the lowering block). As you can see here, mine is broken.
  2. squirrel
    it's called a "spring seat"
    same one was used on cars for many years, and trucks also starting in 1948. should be easy to find a replacement, but it will probably be a used part, not new.
  3. 56sedandelivery
    56sedandelivery
    We call them spring pivots. And, I happen to have TWO of them we took off the 51 Bus Coupe. You can have them both for shipping costs. Just send a PM. I am Butch/56sedandelivery.
  4. squirrel
    heh...that's the "easy" way to find them!
  5. 302GMC
    302GMC
    from Idaho
    Why not de-arch the springs, or at least buy the right u-bolts for those blocks.
  6. Yeah, the uneven stress from those U bolts may have caused the failure. Get some flatter U bolts that contact the spring seat fully
  7. Mr48chev
    You absolutely need the correct square U bolts on that rig.
  8. squirrel
    while you're at it, make sure the blocks are not wider than the springs. It appears they are.
  9. 56sedandelivery
    56sedandelivery
    In looking further at your photos, it's easy to see why this happened. You should be using "squared" end U-bolts instead of the "rounded" style you have on there. It is stressing the metal, and causing it to crack/break. If the U-bolts are long enough, you could possibly weld in a "bridge" to make the ends square, but it would be best to obtain the correct style U-bolts. Offer still stands. I am Butch/56sedandelivery.
    DANG!!! I TYPED THIS EARLIER, AND NEVER ENTERED IT.^^^^^ALREADY ANSWERED^^^^^.
  10. Chris-Bartlett
    Chris-Bartlett
    Thanks for the offer, Butch. Also, correct flat U-bolts ordered.
  11. Jkustom
    Jkustom
    I'm glad a few beat me to it.. Get the right U bolts, and the right width blocks, 1.75" wide If I remember from when my car still had leafs. I might even have my old ones, I'll take a look.
    Slow down likes this.
  12. I have seen those break even when no lowering blocks were used. There are a couple of different types, one is all centalised (like yours), the other has an offset pin and a long & short "ear" where the U bolts seat.
  13. Lone Star Mopar
    Lone Star Mopar
    They sell the correct width blocks and u bolts for your 51 pretty cheap.
    Sent from my SM-J727T1 using The H.A.M.B. mobile app
