54 Chevy Quarter Window Installation Question
Discussion in 'The Hokey Ass Message Board' started by rockable, Oct 14, 2012.
  1. rockable
    rockable
    I ordered new metal sash channels from Chevs of the 40s and had to weld my old brackets onto them to make them work. They sent me some of their 4082810 setting rubber. It does not fit the channel or the gl***. The rubber seems to be made for thinner gl*** and it does not have enough bulk to stay seated in the metal channel.
    Obviously, something is wrong here. Can anyone tell me what I really need?
  2. oilman
    oilman
    Im not sure about a 54 but on a 55 the gl*** setting rubber is really tight, I usually set the gl*** on a thick blanket and put the rubber on the gl*** and then windex on the outside of the rubber and use a rubber hammer to tap the channel on the rubber. That seats it on the gl*** and is done.....good luck
  3. rockable
    rockable
    I seated it. It just isn't thick enough to stay in the channel.
  4. can you post some pics? they are usually tuff to get in. i have had them want to slip out once installed. sometimes i've just waited until the "lube" drys, and they'll stay put. other times i've used weather strip adhisive to make them stay in place.
  5. 56premiere
    56premiere
    i recently done my lincoln,got setting tap at local gl*** co. 2 different thickness,you may have to try that. good luck
  6. 325w
    325w
    Pinch the channel together a little more than you need for the gl*** to hold then do as the others suggested. The setting tape is a better method. Lota times the rubber will let go. You can use electrical tape to hold the setting tape in place the trim all with a razor blade after you get itin place.
  7. rockable
    rockable
    I'm calling Steele Rubber tomorrow. Thanks.
