54 chevy rear end converison
Discussion in 'The Hokey Ass Message Board' started by killer green, Oct 26, 2012.
  1. killer green
    killer green
    hay ya'll don't know if i'm doing this right, like 2 say thanx for lett'n me n ya'll group. gonna put a 78 camaro rear end in my 54 chevy 210 do i just use the rear end or springs &all ,thankx ya'll, oh yea if i'm not ask'n the questions in the right place and all , let me know because i'm not to good with computers either. thanx again KILLER GREEN
  2. engine138
    engine138
    from Commack NY
    Welcome and use it all ditch all the oem stuff
  3. Morgan91
    Morgan91
    from Australia
    Yeah ditch the stock springs they are to narrow.
  4. killer green
    killer green
    do i use the mounting brackets from the camaro or use the stock one's or u gotta buy something, thanx for your help
  5. mailerguy1
    mailerguy1
    I used the Chassis Engineering kit to put a 68 camaro rear under my 51 Chev. After grinding out the rivets everything bolted back in and I just had to drill 4 more holes to finish bolting the parts. They also have a crossmember for the shocks that also will bolt in. Hope this helps. Welcome aboard too :D
  6. Morgan91
    Morgan91
    from Australia
    Pretty sure you can buy a kit Mabey from chevsofthe40's
    But you could fairly easily modify the stock mounts and make up some shackles.
  7. Morgan91
    Morgan91
    from Australia
    That's sounds like the go!
  8. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    You can bolt the Camaro rear onto the stock springs. If you want to go the low buck route all you have to do is drill a new hole for the spring bolt 1-1/2" forward from the center on the Camaro spring pad. Pinion angle is not going to be right as is. I removed the spring pads, rotated the rear to get the correct angle then welded the sping pads back on. Same could be done with some wedge shims.
