1952-59 Ford 54 Column shift conversion ... manual to automatic?
Discussion in 'Off Topic Hot Rods & Customs' started by alteredpilot, Mar 28, 2011.
  1. my 54 has something of a not so attractive floor shifter conversion from when a previous owner installed a 302 an C4, and i'd like to eliminate it while moving the shifter back up to the column.
    does or has anyone used the stock manual trans shifter ***y to come up with some means of shifting an auto OR is there a column shift conversion available for this vehicle?
    thanks for any input.
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    I tried that and after a lot of frustration and almost ending up in anger management I went the floor shift route,now if you were to put in a 52-55 Ford-O-Matic column in there you could make that work with the C4 pretty EZ.
  3. old lady's mad
    old lady's mad
    mine has the factory auto column on a aod.
  4. gregk
    gregk
    from BC Canada
    I used the stock fordomatic column shifter to a C6 auto. Some 1/4" rod and a few couplers with a few bends in the right place and it works great. I had to do some work on the shifter lever at the steering wheel to be able to get the 3 drive positions on the C6. Some not so fancy file work creates another position for low gear. The fordo only had two drive positions. When i had the steering wheel off, I noticed that the lock which is used in park, was just about worn thru. This was a result of many years of grabbing the shifter and dragging it down into drive, rather that pulling the lever back towards the driver before placing in drive.
  5. gregk
    gregk
    from BC Canada
    I was able to dig out a photo of the shift rod that i built. It's kind of out of context but you get the general idea.
  6. 2cdans
    2cdans
    If you don't care about using a stock column, a column from a 1963 Galaxie is an easy swap. I also used the galaxie steering box (with pitman arm) and it was a bolt in. The colour coding on the wires for the signals was even the same as the 54 wiring. It is hooked to a C6
  7. My55fairlane
    My55fairlane
    how would the columns work with a AOD since there is 3 positions for drive then N and R and P...I dont care what column I use as long as it looks good in the car and cheap
  8. old lady's mad
    old lady's mad
    mine was done by p.o. they cut and rewelded the little arm on the bottom. i can take a pic. i realy dont know if it gose all the way to low. i just use drive and o.d. im not racing it.
  9. My55fairlane
    My55fairlane
    So any one know if those galaxie cruise o matic columns would go into a 55-56 fairlane...since there is three positions...so would have OD - D- 1
    how would mounting it look...would I need a custom delete plate at that point
    and also to hook up everything else...****** and steering
  10. JeffB2
    JeffB2
    from Phoenix,AZ
    If you look at a Mustang C4 shifter and a Mustang AOD shifter you won't see a difference,there is not an extra detent for Overdrive like on a GM Overdrive.
  11. My55fairlane
    My55fairlane
    what you mean by detent?
    cause the 90s aod mustang shifter has a OD spot and drive and 1st gear
  12. JeffB2
    JeffB2
    from Phoenix,AZ
    To adapt from an automatic column to an AOD look up a Lokar part# ACA-1807 you might send Don (aka rustyfords) a pm I think He may have posted a link with pictures.
  13. My55fairlane
    My55fairlane
    I would love to keep a column shift for the aod in my 55 instead of doing a floor shift
