1952-59 Ford 54 customline 302 swap with t5 transmission
Discussion in 'Off Topic Hot Rods & Customs' started by RAMOS17, Sep 13, 2015.
  1. RAMOS17
    RAMOS17
    from COLORADO
    Hello everyone, just looking for some advice on a 302 swap, motor mounts, transmission mount, etc, any info would, thank you
  2. HOTRODPRIMER
    HOTRODPRIMER
    I used 84 Mustang motor mounts and fabricated a new cradle for the 5 speed transmission.
    Check out my wagon build site,there are some photo's of the transmission cradle. HRP
  3. HOTRODPRIMER
    HOTRODPRIMER
    There is another piece that fits just below the shifter that is a U shape to clear the bottom of the shifter that ties the X member together.HRP
    voodookustoms likes this.
  4. mnfordfan
    mnfordfan
    what do you guys use for a clutch pedal, and clutch ***embly?
  5. HOTRODPRIMER
    HOTRODPRIMER
    Fortunately,the wagon was a straight drive so I just adapted the '84 Mustang quadrant to the clutch pedal which was a simple task and I used the Mustang cable,,so no jack shafts,no slave clutches.
    This is a photo from the internet but it is the style I used
    This is the cable going through the firewall.
    another internet photo but it looks like mine. HRP
  6. mnfordfan
    mnfordfan
    That is awesome hotrodprimer! So you used the original pedal ***embly under the dash! I like that much better than a slave cylinder etc. Looks like you have lots of room! Amazing clean underhood picture by the way, super clean
  7. HOTRODPRIMER
    HOTRODPRIMER
    Yes,I pulled the Mustang clutch and brake ***embly and was going to use it but it just didn't look right,so I just removed the clutch quadrant and adapted it to the '54 clutch pedal.
    There is nothing wrong with slave cylinders but the cable although not pretty works like a champ and is easy to service should I ever need to replace it and was also easy to install.
    As for under the hood I got a little **** but I also kept it simple with paint and attention to detail..thanks for the compliment.HRP
  8. voodookustoms
    voodookustoms
    That looks great. I'll be doing this soon with my car. Collecting parts for it now. I was able to find, with the help of a friend, an original clutch pedal ***embly from a manual car I'll switch out with my setup.
  9. JeffB2
    JeffB2
    from Phoenix,AZ
    There are always guys looking for a Ford-O-Matic column and matching pedal setup when swapping from a stick to C4 or AOD,since you are going manual post the parts you have maybe a swap or sale can be worked out,maybe here: http://www.jalopyjournal.com/forum/threads/auto-trans-steering-column.991871/
  10. voodookustoms
    voodookustoms
    Thanks for that Jeff! I just hit him up!
