Technical 54 dodge pickup rear end
Discussion in 'The Hokey Ass Message Board' started by jason mcleod, Dec 28, 2016.
  1. jason mcleod
    jason mcleod
    my factory rear end its done...i read you can use a 8.8 91-01 ford explorer rear end..it has the same bolt pattern 5x4.5...is this correct...thanks
  2. gene-koning
    gene-koning
    Yes. It is a touch on the narrow side, my son had to order wheels with special backspacing to clear the inside body on his 57 Dodge wagon, you might be OK with a truck. You can get a drive shaft yoke that will match the small Mopar U joint as well. I'll have to ask my son where be bought it from, wasn't expensive, Think maybe Denny's Driveshaft, or something like that. Gene
  3. jason mcleod
    jason mcleod
    ok thanks and please let me know
  4. 73RR
    73RR
  5. jason mcleod
    jason mcleod
    something is wrong with there sign up...its down when you try to put in there screct answer it doesnt work
  6. 73RR
    73RR
    That was a problem awhile back for folks with gmail accounts.
    Can you access from another computer?
  7. jason mcleod
    jason mcleod
    let me try thanks
