54 ford chop progress
Discussion in 'The Hokey Ass Message Board' started by 54chop, Jun 14, 2006.
  1. 54chop
    54chop
    Krooser, Squablow, Talltom and others have wanted to see some pics. Was waiting to get the windshield in. Hasn't happened yet. Everything takes longer than planned, so here they are. 54chop
  2. Tore
    Tore
    Nice .Is that a converted 4door ?
  3. 54chop
    54chop
    No, it's always been a 2dr. When I chopped it, I rolled the back window down 3.5" and fit he roof to it instead of moving it all the way forward to the A pillar.(quartered the roof) 54chop
  4. HOTRODPRIMER
    HOTRODPRIMER
    Very nice chop!:D HRP
  5. LoungeLife
    LoungeLife
    from Tulsa
    Btichin - how you cutting the gl***?
  6. 54chop
    54chop
    The only gl*** that needed to be cut is the windshield. I made a template of the opening and had Rockford Auto Gl*** cut it. Just need to finish sanding the top edge and install it. 54chop
  7. pimpin paint
    pimpin paint
    from so cal
    Hey,
    Thasa killer lookin chop! 52s, 3s & 4s are tough to get the line and flow
    of the roof, without that sat on look.
    S****ey Devils C.C.
  8. Flatattack
    Flatattack
  9. Squablow
    Squablow
    Looks real good. First car I ever chopped was a '53 Ford two door sedan, still got it. Mine didn't turn out quite as nice as yours did, but I still get compliments.
  10. 54chop
    54chop
    Probably worked with hammer and dolly for a week to get the crown right. Next time it won't take nearly as long. Started to mig it together, but that creates hard spots I discovered. Finished welding the top and did the back window(from 53 chev sedan) with oxy-acetylene. That hammered out much better. 54chop
  11. FiddyFour
    FiddyFour
    nice work... REALY well done indeed :cool:
  12. dingleberry
    dingleberry
    that shot from the left side looks really good
  13. 54chop
    54chop
    Looks the same from the right side, just didn't want to fill up the post with too many pictures. Squablow, be happy to do the roof for you on your 53(for trade or cash). You always seem to have a lot of interesting iron. 54chop
  14. RATCAMINO
    RATCAMINO
    nice chop do you have any close up pictures my buddy is thnking about chopping his it would be a great help
    jake
  15. FiddyFour
    FiddyFour
    *sigh*
    mine could use a lil off the top... projects, money and time. got plenty of the first one, little of the second and almost none of the third :rolleyes::p
  16. "What's it look like when you chop a 53/54 210/BelAir and leave the back gl***?"
    That answers that question.
  17. 54chop
    54chop
    Time to post an update. Windshield is fitted and in. I think I know why there are so many chopped projects for sale w/o gl*** cut or installed. Got the rest of the car painted. Waiting for paint to cure before putting on the stainless trim. Have yet to put the 3" lowering springs in, definately needs 'em. Comments welcome. Later, 54chop
  18. Looks great...will look even better with the new stance!
    Bryan
  19. it looks like a checker cab to me with 2 doors removed
    nice
    tom
  20. 54chop
    54chop
    So, are thinking it's because of the ride hieght, because I have never seen a chopped checker cab. Or is it something else? 54chop
  21. hudsoncustom
    hudsoncustom
    That looks like a nice chop.
    I hope you don't mind, I wanted to visualize it with a lower stance....
  22. it is tall in the pics, thats got to be it
    i still think its nice
    tom
  23. Squablow
    Squablow
    Can you explain this in more detail, or do you have pictures? I don't get what you did here. It looks good, about as chopped as my '53 is, but you have a shorter quarter window. Did you move the rear window further forward? I'd like to know so when I go over my '53 the next time (did the chop 10 years ago, I was young and inexperienced) I can make some changes.
  24. 54chop
    54chop
    The 1/4 window is the stock one that was never removed when I did the chop. I did however duct tape it just to keep from getting any damage. I rolled it down 3.5 inches and moved the top forward(and down) just enough to close up the gap. Then I had to cut across the roof(left to right) to move the front half of the roof the rest of the way to the "A" pillar. At the time I thought moving the roof forward without cutting across the roof would make the 1/4 windows look too small, but looking at Seymour's car(green 54 business coupe I believe) I don't think this is true. The proportions on his ford's 1/4 gl*** looks good. 54chop
  25. Bondoboy
    Bondoboy
    Looks bad*** but I dont think a 3" drop will be enough..but it looks good..
  26. Squablow
    Squablow
    So the rear of the roof actually came forward? That was what I was wondering. My car is chopped about the same amount but my rear windows look longer (which I don't like, I like yours better). Did you have to add any length to the roof when it was cut, or did moving the roof forward eliminate any need to do that?
  27. 54chop
    54chop
    I did have to add some length to the middle of the roof to get it to reach the "A" pillar. About 1 1/2". 54chop
  28. Custom54
    Custom54
    Very nice work. Do you know how the gl*** guys cut the gl*** (sandblasted or?).
  29. 54chop
    54chop
    Forgot the picture. You can see where the roof was extended. Should have added to the roof further forward. You can see by adding 1 1/2" right in the middle of the roof I lost some crown and caused much more hammer and dolly work. 54chop
  30. 54chop
    54chop
    The guys at Rockford Auto gl*** told me they cut it 3/4" at a time. I think that works out to 5 or 6 times. 54chop
