'54 Ford rear end
Discussion in 'The Hokey Ass Message Board' started by Dammit, Jun 15, 2011.
  1. Dammit
    Dammit
    from Canada
    Ford gurus, I need your help. I've dis***embled a '54 Ford car differential and need to know if the spacer on the pinion is the colapsable type? It appears that it is, but the only info I have on setting the pinion bearings talks about the shim behind the rear bearing. If anyone has a real Ford manual and could look this up, I would really appreciate it.
  2. squirrel
    THe pinion depth is set with a shim, the pinion bearing preload is set with the collapsible spacer. This is from an old Chiltons manual, and is how most pinions are set up.
  3. Dammit
    Dammit
    from Canada
    Thanks, squirrel, that's what I needed.
