Projects 54 GMC 270 swap, motor mount help
Discussion in 'The Hokey Ass Message Board' started by Mike Hoffman, Nov 13, 2023.
  1. Mike Hoffman
    Mike Hoffman
    Hello everyone. First time post here, thanks for any help provided.
    I've started a project with my uncle's 54. We are swapping in this built 270 with a Turbo 350 ******. I've got it bolted back in, but I'm concerned about the motor mounts. The front mount combined with the transmission mount does not give much support for the torque of this motor. I cannot find a good place to bolt new mounts to the engine block. It looks like the 265 has empty bolt slots to add motor mounts, but this 270 does not.
    Any advice on securing this motor?
    As soon as I figure out how to post a picture, I will add a couple shots of the build.o_O
  2. 302GMC
    302GMC
    from Idaho
    The truck bellhousings used side mounts that stabilized the torque. You'll need to figure a way to duplicate that feature.
  3. jimmy six
    jimmy six
    If you can place some kind of a bolt in crossmember at the front; then make side mounts at the front that bolts to the side of the block you won’t need a mid mount. In the 2 photos there in a 2” channel iron bolted to the frame with fabricated side mount out to the inner edge of the that sits on the channel. Tough to see the left side because of the oil filter mount. Expand the right side photo to see what I mean. IMG_2895.jpeg IMG_2868.jpeg IMG_2715.jpeg
    Ace61 likes this.
