1952-59 Ford 54 lowered strut replacement gurus!!
Discussion in 'Off Topic Hot Rods & Customs' started by solo_909, Jul 13, 2011.
  1. solo_909
    solo_909
    Hey guys so I just received my Aerostar coils and 4" blocks. I was doing some research about replacement of the struts and couldn't figure it out.
    So heres what I was I found out about the (front shocks)When swapping to the Aerostar coils it will give your car 2+ inch drop. I was looking at swapping out the shock but found that the 54 stock shocks have a 13.42 in. extended length
    8.56 in. collapsed length well I was thinking the best way to swap out would be to use the stock aerostar shock because it's men't to go with that coil spring. Well the Aerostar shock has a 15.13 in. extended length 9.75 in. compressed length which is about the same. Anyways So what do I use? Should I replace both shocks with a shock that is 2+ inches shorter than stock and aerostar?
    Thoughts? I'm so confused with this whole situation.
    Any help would be greatly appreciated!!
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    Your stock shocks should work with the Aerostar springs if they are a Gabriel replacement shock,it seems they are shorter than the OEM Ford shocks were.When I replaced the shocks on my '54 I had the rear wheels off and when I went to put them on they would not go in the wheel well because the axle would not drop down as far so I checked the fronts and same deal almost 1 1/2" shorter.
  3. solo_909
    solo_909
    I'm not quite following you. The back shocks is a whole different situation because when you lower the back using blocks your actually creating a longer distance between the to mounting on the axle and leaf spring plate. So with the rear you would need a longer shock to compensate for the 1"-4" blocks you installed between the axle and spring plate. With lowering the front sense the coil is shorter and allows a 2+ inch what is the correct shock to use?
  4. JeffB2
    JeffB2
    from Phoenix,AZ
    duplicated post computer glitch
  5. JeffB2
    JeffB2
    from Phoenix,AZ
  6. sircampsalot2
    sircampsalot2
    I used the shorter Gabriel shocks from Autozone and I think its going to cause a problem down the road due to it seems theres not enough extended travel in my opinion. If I had to do it over again I would go with the Aerostar springs your talking about. When I jack my car up with these new springs and shocks the tire comes off the ground Immediately so it makes me think if I hit some good hills in the road or a speed bump its going to ride like hell over them. (I'll know once I get it one the road) But from just bouncing the car up and down this is what I think may happen so with it being a pain to change them I wish i had opted for a longer travel shock.
  7. solo_909
    solo_909
    Sirca - are you talking about the front or rear tires coming off the groud immediately when jacking it up?
  8. sircampsalot2
    sircampsalot2
  9. solo_909
    solo_909
    Hmm yeah that's wierd. The thing I don't understand is how the shoals for the stock coil amd the stock aerostar coil are about the same demensions even though the aerostar coil is way shorter in length.
  10. solo_909
    solo_909
  11. sircampsalot2
    sircampsalot2
    I dont know but with the shorter shocks there isnt much articulation for sure
  12. parklane
    parklane
    The length of the shock is determined by where the mounting points are on the lower A arm and on the frame, so if the Aerostar upper mount is high, it will require a longer shock. Clear as mud???
  13. solo_909
    solo_909
    Make sense but how do I figure out what to use for the front shocks?
