1952-59 Ford 54 rearend drain bolt
Discussion in 'Off Topic Hot Rods & Customs' started by 52plymouth, Aug 25, 2010.
  1. 52plymouth
    52plymouth
    somewhere else i asked im trying to get the drain bolt out of the rearend in my 54 customline the fill bolt i can get loose with a 3/8" ratchet extension but the drain bolt is between a 1/4" and 3/8" so im guessing 5/16". so i thought of getting a piece of 5/16 square stock with a crescent.but i rather use a proper tool for the job.any feedback would be appreciated.
  2. i have the same problem with my 55 fairlane..it actually takes a special tool... so here's what you do..clean the hell out of the drain plug..and weld whatever size nut you have laying around to it.that way you can use a socket on it..or if you do happen to get it out..replace it right away with a new plug.
  3. 52plymouth
    52plymouth
  4. 10bucks
    10bucks
    It is 5/16". You can get the 5/16 drain plug socket from your MAC tool guy. Or any other competant tool peddler for that matter. ( I think mine are Snap-on) But your square stock idea will work in a pinch. keep in mind the stock is kind of soft and you might twist it off a time or two. I used to change oil in my 54 rear every engine oil change. Just because gear lube was cheap and gears are generally not.
  5. 52plymouth
    52plymouth
  6. old lady's mad
    old lady's mad
    want me to tell you what i done . i took a cheap 3/8 drive extension. and ground it down on the grinder . only needed it a few times and it works
