1952-59 Ford 54 trans. size help
Discussion in 'Off Topic Hot Rods & Customs' started by Colombo, May 28, 2014.
  1. Colombo
    Colombo
    OK fellas I need some help please.
    I have a 54 Customline with a 239 Y-block and three on the tree with the overdrive option. I have to buy a clutch ***embly due to it not engaging into gear without slamming it in. I have adjusted the fork and can get it to work great but not sure how long that will last. I may have tighten the nut to much due to the burning smell when I shift.
    A buddy of mine works at a shop and has offered to switch out the ***embly which would be much faster to do than at home with a floor jack. According to the book it shows two different sizes to choose from for both pressure plate and clutch plate. How can I tell what size I have without taking it apart first? Should I order both sizes and return the one I don't need? The work would be done on a Saturday when the shop is closed and according to him it would only take 3 to 4 hours to complete.
    Anyone know what size I will need or parts? throwout bearing?
    thanks in advance.
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    Order both and the throw out bearing and pilot bushing,after 60 years you never know what might be in there.
