Technical 55 210 Horn issues
Discussion in 'The Hokey Ass Message Board' started by Mikey Bishop, Nov 14, 2025.
Tags:
  1. Mikey Bishop
    Mikey Bishop
    I have a 55 210, completely rewired with an off-brand universal wiring kit, aftermarket horn.
    Horn keeps blowing when I hook it up. Replaced the steering bushing that was really worn out and had several cuts in the wire. New bushing did the same thing.
    Figured out if I didn’t push the new bushing all the way into place, it would work correctly. If I push it all the way into place, horn wire would make constant connection.
    Got a new steering bushing today, installed it, gown worked correctly. ….for about 10 minutes. The. It just started blaring.
    any idea what the issue could be or what my next step should be for getting it to work correctly?
    (new mooneyes steering wheel if that makes any difference)
  2. squirrel
    the bushing went all the way in when you started driving. So you need to figure out why it shorts when it goes in all the way.
    You're gonna have to post some pictures of what you're working on, for us to be able to help you.
  3. Mikey Bishop
    Mikey Bishop
    What parts should I take pictures of? Should I take the steering wheel back off and pictures of the bushing?
  4. DDDenny
  5. 325w
    325w
    Done several tri fives the horn is picky. One time no issues next time some sort issue.
    Double check the green horn wire from beginning to end at horn.
  6. Mikey Bishop
    Mikey Bishop
    I have. The green wire is good. I just took the steering wheel back apart. If I pry the steering bushing out just a little, horn works as it should. If I push it all the way into place, it makes constant contact.
  7. 57Fury440
    57Fury440
    Without seeing a picture this is just a shot in the dark. Can you try putting some plastic washers behind it so it can't be pushed in any further?
  8. Mikey Bishop
    Mikey Bishop
    I’ve tries uploading pictures, but it keeps saying “file too big”
  9. Mikey Bishop
    Mikey Bishop
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Appears the insulation under the shoulder of bushing is non existent or breached. IMG_4945.jpeg
    Just Gary and squirrel like this.
  11. squirrel
    Remove the bushing, and look at it to see if you can see what could be shorting. Look in the hole in the column, as well. Pictures of your bushing, in the position of the other one shown above, will let us see where the problem might be.
    rod1, RICH B and Johnny Gee like this.
  12. Mikey Bishop
    Mikey Bishop
  13. Mikey Bishop
    Mikey Bishop
  14. Johnny Gee
    Johnny Gee
    from Downey, Ca
    About having the bushing elevated and no issue. What steering wheel? All steering wheel horn related parts correct? If contact pin is over extended in length it will wonder and do funny things.
  15. Mikey Bishop
    Mikey Bishop
    It’s a mooneyes grant style steering wheel. All the steering wheel mounting and horn parts are correct for that steering wheel
  16. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Ya, but it’s all aftermarket. Grants are fun to get right.
    427 sleeper likes this.
  17. squirrel
    It looks like you fed the wire into the turn signal housing? It's supposed to go straight down in the column. I wonder if that is messing it up somehow?
  18. Mikey Bishop
    Mikey Bishop
    I did run it that way. I’ll see if I can re route it tomorrow and give that a shot.
  19. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Good catch.
  20. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Woke up this morning thinking wait a minute. The shift tube and shift collar will not allow the horn wire to go straight down. Been at least 3 years since I tore into one. Be it 57 however same internal set up. IMG_0270.jpeg
    Out in the shed I have a 55-56 column. The shift tube goes into the shift collar then into the signal housing as a pivot point so no p***age that way. The wire has to run outside of shift tube making Op’s route correct.
    squirrel likes this.
  21. squirrel
    thanks, been a long time since I fiddled with one that still shifted on the column.
    there has to be something making it not work...I think the first thing to check would be resistance to ground to the contact, with the relay disconnected, and the bushing fully inserted. An ohm meter is going to be pretty handy to help figure this out.
    Johnny Gee likes this.
  22. 325w
    325w
    The wire goes between the shift and the column. Comes out of column just below the dash.
    I’ve always had issues using after market kits.
  23. Oneball
    Oneball
    The bit I don’t understand is why it’s blowing the fuse. The horn contact grounds the horn circuit and the horn makes noise. If the collar wasn’t insulated properly youd just get the horn sounding not the fuse blowing. For the fuse to blow there has to be something else wrong doesn’t there? Have you wired the circuit correctly to begin with?
  24. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Fuse? What did I miss?
    Oneball likes this.
  25. Oneball
    Oneball
    ****ing idiot aren’t I! Blowing the horn not blowing a fuse. Doh!!
  26. To stop you (and the neighbours) going insane when working on a horn, replace the horn with a light globe and place it on the windscreen so you can see it. I did this after my wife came out and thought I had injured myself and was trying to signal for "Help"!
