Customs 55 230 flathead Plymouth Help.
Discussion in 'The Hokey Ass Message Board' started by Our 55 is alive!!, Jun 25, 2014.
  1. Our 55 is alive!!
    Our 55 is alive!!
    Removed timing cover seal and cleaned up the cover forgot to see which way the seal goes in, some help please.
  2. 73RR
    73RR
  3. Our 55 is alive!!
    Our 55 is alive!!
    My seal doesn't look like that one. Or is that just an example?
  4. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    The lip points in toward the oil. Some have a dirt seal that usually has a smaller lip, which points out. Easiest way to tell which way is in or out is to look at the metal part. The side that is totally closed off by the metal faces out. On the picture posted by 73RR, the seal on the left shows the outer side. If I remember correctly, the timing cover on these engines required a locating sleeve that went around the crankshaft snoot for alignment purposes. The cover slid over the sleeve, a couple of bolts installed and the sleeve pulled out. I suppose you could align it with the crank pulley. If it's out of line it will leak. Have fun..............
    --Glenn--
  5. RCebreros
    RCebreros
    Glenn's right. Rule of thumb, lip faces the side you want to contain.
