Technical '55 265 Temp Sender
Discussion in 'Traditional Hot Rods' started by 2935ford, Jan 30, 2014.
  1. 2935ford
    2935ford
    Is the hole in the back of the intake manifold for the temp sender on a '55 265 NPT?
    I read somewhere that for this year it was in combination with the temp gauge......you needed both the sender and that gauge for it to work as both parts were specific for that year only?
  2. Andy
    Andy
    Well, you need both parts because it is a mechanical gage with a capillary tube. The individual parts ar not going to work without the tube. I think the manifold port is straight thread and a loose nut on the tube/bulb screws into it to install the bulb.
  3. squirrel
    yup, in 56 they switched to electric, I put a 56 gage and sender in my 55
  4. 2935ford
    2935ford
  5. x 2
  6. 2935ford
    2935ford
    squirrel, what sender did you use? Do you have a part #. The one I picked up supposedly for a '56 is way to big for the hole.
  7. Bob W
    Bob W
    from Here
    Bolt a 56 or newer intake on to it. Or get a mechanical gauge that will fit the female tep gauge hole in the 55 intake. 55 is a one year deal.
  8. 2935ford
    2935ford
    I guess it would be good to mention....my '55 engine is in a '32 pickup.
    I'm also running an elec fan and have a thermo cover that will accept an NPT fitting for that sender.
    I'm wondering if I can use a coupler to fill the oriignal sender hole to use the '56 sender?
  9. squirrel
    look carefully at the thread on the sender hole, it's probably not pipe thread.
  10. 2935ford
    2935ford
    I don't believe it is.
  11. hoop98
    hoop98
    from Texas
    5/8 x 18,
  12. 2935ford
    2935ford
  13. hoop98
    hoop98
    from Texas
    If you want electric
  14. squirrel
    ...and you only really know how warm the engine is after the thermostat opens...
  15. 2935ford
    2935ford
    Thanks. I have one of these for my elec fan.
