1952-59 Ford 55-56 parts
Discussion in 'Off Topic Hot Rods & Customs' started by 55customlinecowboy, Feb 9, 2019.
  1. 55customlinecowboy
    55customlinecowboy
    I just brought home a 1956 ford parts car. I'll be using the control arms and rocker panels. The dash is gone and its its hit in the back. Right side inner wheel house is fine and trunk pan could be used for patches. Floor plans are good. The front spindles and brake parts and the rear diff are up for grabs. Got a a ***le, vin tag and frame #'s. Rear windows and regulators are good. PM with needs and we will talk. I wanted to offer the stuff here before the cl***ifieds. 20190209_153613.jpg 20190209_153555.jpg
    Bleach and JeffB2 like this.
  2. Texas57
    Texas57
    That's a good match for the rear clip you posted earlier!
  3. 56longroof
    56longroof
    How are the fenders?
  4. Bleach
    Bleach
  5. 55customlinecowboy
    55customlinecowboy
    I thought about it, but man its a lot if work. Told my wife if I did it that it would be a permanent convertible.
  6. 55customlinecowboy
    55customlinecowboy
    P***enger side is good. The drivers has a dent. Could be worked out.
  7. 56longroof
    56longroof
  8. mjlangley
    mjlangley
    from SE MI
  9. Rui
    Rui
    Could you post a picture of the front so I can see the grille?
    Thank you.
  10. 55customlinecowboy
    55customlinecowboy
    The grill is toast. Someone kicked it in.
    Rui likes this.
  11. 55customlinecowboy
    55customlinecowboy
    Steering column, master cylinder, brake pedal, clutch pedal, front spindles, rear diff, rear side windows and regulators, p***enger rear inside window trim, rear seat, front seat cushions, park brake handle ***embly, front bumper brackets, park light housings (light pitting), throttle linkage mounted to fire wall for a Y block. I'm taking this thing apart. I'd you need anything I'll make a good deal. Want you guys to get first shot. Next week I'm putting it on the cl***ifieds and Craig's list.
  12. fiveoh108
    fiveoh108
    Hello, I am looking for the ford o magic steering column so I can run a C4, do you have that one? Also headliner bows, my car has none (55 Victoria)
    Thank you!
  13. okiedokie
    okiedokie
    from Ok
    I see that on Facebook there is a page dedicated to buying/selling 55-56 parts.
  14. Venom51
    Venom51
    I need a driver side vent window pivot. Any chance yours are in working condition?
  15. Texas57
    Texas57
    I'm curious if you're looking for the TOP pivot (I don't have one), and if they are made the same way the '57s are. I recently broke my top pivot. Poor design....the top pivot pin is necked down/grooved from 5/16 to just 1/8", and that's where they break. I thought I might have had a spare from a wing widow extra frame I had, but it was broke there also. Problem with replacing, if you can find one, at least on '57s, is the bracket that holds that pin is riveted to the vent window frame, and there's no way to replace it with the gl*** in.
    I may have a solution........I'm going to look for a headless 1/8"drill bushing with a 5/16 body, and try and drill out the shaft, then insert a 1/8 dowel pin with loc***e, maybe even using the drill bushing left in place . The drilling would be done with everything ***embled in the frame, and the small retainer strap holding the bushing instead of the broken pin. Better yet, after drilling, would be to remove the bushing have a stepped pin made that would be a light press fit (or loc***e) into the hole. That way, the split nylon bushing would have it's intended purpose of putting some drag on the pin.
  16. Venom51
    Venom51
    I need a bottom pivot.
    Your pivot sounds like a real headache but your solution makes sense!
  17. Texas57
    Texas57
    Got a pic? I've got a '57 bottom pivot (if it's the same) you are welcome to.
  18. Venom51
    Venom51
    I’ll get a pic and send it your way. Thanks Texas!!!!!
  19. 55customlinecowboy
    55customlinecowboy
    I was trying to sell the doors whole. If that falls through I'll piece them out. All of the vent window stuff is there and working.
  20. Venom51
    Venom51
    Not a problem. Just thought I’d try. Thanks!
  21. Texas57
    Texas57
    Venom:.........the '57 lower pivots I mentioned are totally different. They possibly could be subs***uted, but not something you'd want to do unless you were in a tear down stage. Vent gl*** would have to be out, and rubber seal out of the main vent window frame as well. 2019-03-01.png
  22. ToddB56
    ToddB56
    What kind of shape are the front turn signals in? pics? cost?
  23. NewGuyOldFord
    NewGuyOldFord
    Is the front crossmember junk?
  24. guthriesmith
    guthriesmith
    Hey...not looking for any parts but curious if that car came from Edmond? I bought a 36 Ford coupe from the same guy I believe.
  25. customline3859
    customline3859
    How is that front bumper?
  26. 55customlinecowboy
    55customlinecowboy
    I'm not exactly sure what piece you are looking for. All the ebrake parts are there. Is it under the dash?
  27. 55customlinecowboy
    55customlinecowboy
    The front bumper appears to be straight. It's not perfect. I think it may have a small dent. I can take pics tomorrow in the light.
    customline3859 likes this.
  28. 55customlinecowboy
    55customlinecowboy
    Yes the car came from edmond. Its rough but alot of usable stuff. The guy had alot of cars racked and stacked in a corner on 4 post lifts.
    guthriesmith likes this.
  29. 55customlinecowboy
    55customlinecowboy
    Just an update. The doors are good. The front clip minus hood are all usable with a little work. The rear side gl*** and regulators are good. I'll also have a 6cyl radiator that is good up for grabs soon. I'm upgrading to aluminum. The steering box seems good. I have two master cylinders. The rear diff is good. The seats might be clean able. The turn signals are probably only good for parts. Floors are bad, rear quarters are bad. A-pillars are good. Manual steering column is good. I prefer not to try to ship the big stuff. Rear bumper is bad but I think the bumper guards are good. No trim left. might consider selling it all if some one is interested. Good clean ***le.
  30. 50sboy
    50sboy
    Any luck with the e-brake cable clamp and clip? $?
