Technical 55-57 chevy measurement needed
Discussion in 'The Hokey Ass Message Board' started by 57chevymadman, Jul 7, 2022.
  1. Anyone with a sbc in a 55-57 chevy, I'm trying to hide my AC compressor the best I can, car is in paint prison so I'm just mocking it up and tack welding for now
    Need a measurement from this corner of the block to the upper control arm/ control arm bolt, thanks Screenshot_20220706-193412_Gallery.jpg
  2. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    So... I measured 3 ways: left to right
    Corner of block to arm bolt end ( diagonal ) 5 1/4"
    Level straight over to the bracket ( rod like piece that bolts on frame ) 5"
    Level straight and square to top of shock stud 6"
    Have fun.
  3. junkman8888
    junkman8888
    What you are wanting to do does not make any sense; if you (or whoever owns the car after you) decides to install power steering the A/C pump will have to be moved to the p***enger side.
    SS327 likes this.
  4. SS327
    SS327
    Not only that but the hoses are going to have to cross over the engine. They would be too easy to damage or melt from exhaust heat. The fittings also should not be pointing straight up because the oil could get stuck in the compressor damaging it.
  5. Thanks Tom, g***er style build here Definitely no power steering, if someone after me changes things, that is what they're going to have to change along with a lot of things, AC hoses will be custom made and routed nicely along the bottom of the radiator support. Housing end is available with fittings to the rear.
  6. texasred
    texasred
    from Houston
    how do you plan on hiding the vents?
  7. 55 Ford Gasser
    55 Ford Gasser
    Control arm? G***ers have straight axles! Plenty of room for A/C compressor.
    Just kidding, I know not all g***ers have straight axles.
  8. ekimneirbo
    ekimneirbo
    Don't forget that the control arm is going to move up and down. Can't you put it on the other side and mount it lower ? Would simplify hose routing to the condenser and the firewall. Down by the oil pan.:)
  9. wheeldog57
    wheeldog57
    Got to have A/C in a g***er, hmmmmmm
    Special Ed and scotty t like this.
  10. Going to use just the left/right vents black to match the dash, not completely hidden but not as obvious as the center vent, gotta have my 3 pack of stewart warner guages for a 70's style build haha
  11. Looks like it most likely won't work on the placement of the compressor, I'll give it a shot once the engine is in... would have to notch the front xmember to get it any lower, ain't gettin that crazy over it haha
  12. 57 HEAP
    57 HEAP
    I agree, the front crossmember will be in the way.
    Not hidden, but this is my set up.
  13. Looks good thanks!
