55-57 chevy posi question
Discussion in 'The Hokey Ass Message Board' started by joel, Aug 30, 2010.
  1. joel
    joel
    I know the carrier is different from open to posi; what about the pig? I have seen some with the "P" cast on the right side, do you have to have that or will a plain pig work? Also, I found on an old HAMB thread that the posi axles are shorter by 1/8 in.; is this true? Thanks for your help, Joel
  2. Bosco1956
    Bosco1956
    from Jokelahoma
    If you are talking about the housing...Yes you can install a posi in one. Some need a tiny amount of grinding. Yes the axles are shorter for a posi.
    DZAUTO on the chevy talk forum is a master at these old posis check them and do a search
  3. I believe 57 thru 62 are the same. Someone correct me if I am wrong.
  4. Last edited: Aug 30, 2010
  5. Torkwrench
    Torkwrench
    The 55 & 56 axels need to be shortened. Check out www.oldcarmanualproject.com . If you search under Chevrolet Positraction, a list of factory service bullitins will show up. Servicing the 1957 Positraction shows the entire procedure of installing a Posi in a 55 - 56 center section, including shorting the axel shafts. Also, 1957 (and 1958 I think), Posi cases DID NOT have a P on them. My 57 is an original Posi car, and it does not have a P on the case. However the gear ratio code that is stamped on the case shows that it is an original 57 Posi, with a 3:36 gear set. It originally had a TurboGlide, too.....Fortunately it has a Muncie 4 speed now. :D:D:D
  6. olscrounger
    olscrounger
    what torkwrench said--my 57 Fuely has a 3:70 posi with no P on the case--yes axles for a posi are about 1/8 shorter
  7. joel
    joel
    Thanks, guys, this info is a big help
  8. ????? I just pulled the posi outa my 56 and put some taller NON POSI gears in (in a different carrier) and the axles fit just fine,what gives??
  9. Bosco1956
    Bosco1956
    from Jokelahoma
    Its going from a non posi to a posi that the axles are to long.. And the long axles will fit but will **** it up.
  10. super-six
    super-six
    If a modern Eaton posi is used, the axles will not need to be shortened.
  11. posi was new for 57'
