I am wondering if the front sheet metal from a 55 1 ton looks the same as the 1/2 ton and will it bolt on to a 57 3/4 ton? I like the 55-56 look better.
yes. But you need all the sheet metal, it's all a little different. mostly the pieces around the grille opening, including the fenders.
I agree with Squirrel as it changes to accommodate the different grille designs. Hoods will interchange. Sent from my iPhone using The H.A.M.B. mobile app
I did a 57 1 ton that interchanged with 1/2 ton parts, but a friend bought one that had the larger front end like a 2 ton and up truck front. There were a few variations. Like squirrel said, if you change years, you need all of it. I think the rad support has a couple different holes too between 55 and 57 Sent from my iPhone using The H.A.M.B. mobile app
Here's some interesting info on the task force trucks: http://www.modelcarsmag.com/forums/topic/104557-quick-55-59-chevrolet-task-force-truck-id-guide/
