55-57 Ford guys....do your rear leaf spring hangers look like this?
Discussion in 'The Hokey Ass Message Board' started by Fryguy302, Sep 6, 2013.
  1. Fryguy302
    Fryguy302
    from Michigan
    Trying to figure out if this spring hanger/shackle is stock or not. Car sits up a little high in the back. Car is a 57 Fairlane. Thanks for any info.
    Please let me know if your car is set up like this:
  2. Da Tinman
    Da Tinman
  3. The shackle has been 'flipped' down... a common trick to jack the back of the car up.
  4. 1954fordkustom
    1954fordkustom
    It's stock. Flip the shackle inward it will help lower a bit if that's the look your going for
  5. Edsel58a
    Edsel58a
    What 1954ford' said..... Jack the car up, let the rear hang (disconnecting the shocks will help)and flip the shackle over. You need something to put in the space and pry it around. Isn't tough, but be careful.
  6. 57JoeFoMoPar
    57JoeFoMoPar
    yup
  7. Fryguy302
    Fryguy302
    from Michigan
    Thanks, guys.
  8. timothale
    timothale
    get the back of thecar up on jackstands. put a jack from the axle to the frame,pump it down but dont break the shock or brake hose. put a bar in the shcackleland flip it, let the jack down.
