Running a 79 camaro front clip, 350sbc, working on getting the stock steering column working so this truck appears stock from the outside. Power steering, disc's on all 4, and hydraulic clutch for the TKO600. Wondering what anyone has done with the pedal assemblies to clear the steering column. Is there a kit out there that, with some fab, will work nicely with the factory column and look right as well as bolt up to the master cylinder, clutch cylinder, etc. just looking for a little guidence from anyone who has already converted one of these and isnt running the factory pedals that went through the floorboards to the booster under the cab on the frame...... thanks in advance for the help
You might want to see if you can raise the lower end of the column, so it's more of a straight shot from the wheel to the steering box. Then there might be room to hang the pedals and not have them hit the column.
