Technical 55-64 GM 8.4" axle Specs/Info request
Discussion in 'The Hokey Ass Message Board' started by PK Ripper, Apr 7, 2014.
  1. PK Ripper
    PK Ripper
    Does anybody know the specifications (i.e. horsepower & Torque ratings) of a 1956 p***enger car axle? More specificly, will it hold up to 550BHP / 430ft.lbs.?
  2. 1934coupe
    1934coupe
    Only if you use bicycle wheels on it.
    Pat
  3. models916
    models916
    Chevy 8.2 from 61-64 is the strongest. Put in heavy cars with 425 hp and 4sps. Lots of breakage with slicks. Axles twist/17 spline spiders break, left bearing cap will split, pinion will climb the ring gear when the axle tubes flex forward (in that order). All this can be addressed, but it comes out cheaper and much more durable to go to the 9" made just for you ch***is.
  4. squirrel
    ....or use an early 60s Olds/ Pontiac rear if you want the car to "look right"
  5. M224SPEED
    M224SPEED
    from Missouri
    Save yourself all the grief & go with 9" or Dana 60. If you are after the period correct look 59 -64 Olds. Pont. setup ,but those are getting into big $$$ . I.M.H.O.
  6. ididntdoit1960
    ididntdoit1960
    from Western MA
    Yes, the weight of the car, tire choice, and ****** type will play a roll. also, what gear ratio (the pinion gets really small on the steep gears). To address the axles you can use 8 3/4 mopar side gears. later cases had reverse thread bolts holding the posi cases together and were less prone to coming loose. As others have said - some work to get it to live and if plans are for a stick and sticky tires do youself a favor and upgrade now
  7. 327Eric
    327Eric
    It will not hold up to a 427 in moderate tune.
  8. landseaandair
    landseaandair
    from phoenix
    I know for a fact even with the light weight and an automatic, a mild blown 350 in a model A will wreak havoc on a Tri 5 axle. Popped a posi open and broke a cap, knocked teeth off the gears on the next one. Another buddy let his kid drive his '55 (4 speed 300 horse on radials) for a while, went through at least 3 posi third members from the stash before finally wrecking it. Don't know how a 409 Impala could have been raced regularly with one back in the day. Maybe they were just gentle with the clutch or just years less metal fatigue?
  9. 8.8 later model Ford Exploder axles are strong as hell and cheap !! Moser will pull out one axle tube and put in another and supply a correct length shaft to get a normal looking centered pinion, all for around $200.00. That doesn't include shipping but I'm sorta close.
