55-7 Chevy brake drums?
Discussion in 'The Hokey Ass Message Board' started by rusty1, Nov 2, 2010.
  1. rusty1
    rusty1
    are front and rear brake drums on 55-7 Chevys the same?..do the front drums come off the hubs?...seems like I was told this once.
    thanks
  2. 32v
    32v
    from v.i.
    no they are diff. front has bearing in them
    wayne
  3. rusty1
    rusty1
    ...I know the hub would have the bearings, do the drum separate from the hubs?
    ...are 55-6-7 rear drums all the same?
  4. J&JHotrods
    J&JHotrods
    It will once the studs are pressed out.
  5. 302GMC
    302GMC
    from Idaho
    The front drums are riveted to the hub - studs are not swaged. Cut the rivets & the drum comes off.
  6. Here's a good tip. Grind the rivets off of the front drums and remove them. Get a pair of hubs from a 62-67 fullsize Chevy and swap the old ball bearing style hubs up to the tapered roller bearing style! More reliable and easier to buy bearings and seals for! The drums slide right back on.
    57shorty likes this.
  7. inline 292
    inline 292
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
    One word, Yes.
  9. Gas Giant
    Gas Giant
    Fronts and rears are the same after you get past the riveted-to-the-hub thing on the front. Or you may be like me, and someone along the line chiseled them off before you got the car.
    And Ratmotor has a great suggestion; its a cheap easy swap and makes life a lot easier later when you need new wheel bearings.
  10. lawman
    lawman
    I changed my hubs on a 55 years ago to hubs fom a 62 chevy.Very
    easy to do.As I remember Cl***ic Chevy mag ran a "How To".
    Tom (Tired Old Man)
  11. bobss396
    bobss396
    <P>FWIW, '65-ish Impala rear drums are good replacements for&nbsp;the '55-57 fronts. You don't have to rivet them back on either, but I recommend the swap to the later taped roller hubs.</P>
    <P>&nbsp;</P>
    <P>Bob</P>
  12. rusty1
    rusty1
    ...thanks for all the help guys
  13. 1934coupe
    1934coupe
    If you want a set of those hubs I have a pair w/ bearings in them for $35.00 plus shipping you do just remove the rivits and slide droms on.
    Pat
  14. 42hotrod
    42hotrod
    from S.E. Idaho
    If he doesn't want those hubs I'll take 'em for my 55 :D
    Scot
  15. rusty1
    rusty1
    ...I don't need those hubs, thanks
  16. 57shorty
    57shorty
    Hi any chance you still have those hubs?
  17. 57shorty
    57shorty
    Those trucks had 5 lug wheels?
  18. 1934coupe
    1934coupe
    No they are long gone, I price stuff to sell and everything I had is gone.
    Pat
  19. bowtie56jw
    bowtie56jw
    full size p***enger car shorty
  20. 57shorty
    57shorty
    Oh? So the hubs dont have to be from a truck? Id lke to convert to disks.. heard a couple low buck ways useing oem parts... i know i could go modern kits.. heard they space the wheels out further though... mark.
  21. 1934coupe
    1934coupe
    The hubs are 62 to 64 p***enger 65 and later don't work. And most of the disk brake kits do move the wheel out about an inch. I didn't particularly like that look but when I was selling 55-57 stuff most customers didn't seem to mind.
    Pat
  22. bowtie56jw
    bowtie56jw
    shorty you should look at trifive.com there is a bunch of info over there on disc brake set ups.
