55 Ce
Discussion in 'The Hokey Ass Message Board' started by kensousa, Dec 15, 2011.
  1. kensousa
    kensousa
    from McHenry MD
    So I've been searching the boards and I've learned some things but still need to ask a question that I haven't seen specifically asked in this combination.
    I know that you cannot put '55/`56 axles in a '57 housing.
    And I know that you cannot put '57 axles in a '55/'56 housing.
    My question is, can I put a `57 pumpkin/gear set in a `55 housing with `55 axles?
    I've seen comments about cutting 1/8 inch off of the axles but want to confirm that this combination is compatible?
    thanks
  2. chrisntx
    chrisntx
    from Texas .
    one thing you havent learned--We are not mind readers. Is this Chevy? Ford? car? truck?
  3. squirrel
    the pumpkin will swap, only thing you have to watch out for is posis use different length axles (it's only off by a little bit).
    Ce is short for Chevy
  4. low budget
    low budget
    from Central Ky
    The pumpkin will interchange on chevy fullsize cars from 55 to 64,(I think)I have never heard of cutting any off unless maybe the chevy IIs center chunk will also interchange because those housings are narrower.
  5. Must be a Georgia thing. Never heard it in 64 years:confused:
  6. chrisntx
    chrisntx
    from Texas .
    I've never seen that before in my 61 years
  7. Flatheadguy
    Flatheadguy
    At least we now know it isn't a "Vib"
    (valve in block.........flathead)
