Technical 55 Chevy Original Steering box removal
Discussion in 'Traditional Hot Rods' started by PeggySue, Sep 20, 2021.
  1. PeggySue
    PeggySue
    Planning up grade to power steering. Have dual MC with booster, wondering if person jacked font up is I could get box with steering box out the bottom. Trying not to have to take brake lines plus maybe MC out.
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    57 but the same things involved.
  3. PeggySue
    PeggySue
    Thanks I watched it before, but he takes it out the top, wondering about out the bottom
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I just did my girlfriends 56 but engine was out. Even with engine out I had to go over the cross member. Out the bottom no way. Steering shaft will not clear dash enough to angle down at that hard of an angle.
    427 sleeper likes this.
  5. PeggySue
    PeggySue
    Thanks was wondering that. So will have to remove MC and lines or cut steering shaft. Any good method of removing MC without brake fluid all over the place?
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Can you post a picture? I would think moving front seat back (unbolt if need be for more room) should give what you need as far as room. Unless you've got a basket full of snakes for brake lines?
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Never mind, just seen your photo. Leave cap on master as to create vacuum so it won't leak as much (very little at all actually). Brake line will splash more fluid if flicked than master will leak out. Just use rubber caps on lines and wipe right away if any splash happens.
  8. PeggySue
    PeggySue
    Thanks, I was wondering about plastic hydraulic plugs in MC .If I leave fluid in master and plug line connections in MC, shouldn't have to re-bleed MC ?
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    What about u bent under master?
    Wouldn't be easier to pull master with distribution block as a unit?
    jimmy six likes this.
  10. PeggySue
    PeggySue
    Probalaly would MC & Booster
  11. Ebbsspeed
    Ebbsspeed
    I don't have an answer, but am curious what that master cylinder was originally used in? It appears to be very large.
  12. PeggySue
    PeggySue
    Hope to be able to spring U-bend brake line over toward fender enough
  13. PeggySue
    PeggySue
    Don't know was that way when I bought the car
  14. Johnny Gee
    Johnny Gee
    from Downey, Ca
    It's a pot belly copy like the Corvette's used.
    This one is more accurate unit from Raybestos I used on my girlfriends.
    427 sleeper and Ebbsspeed like this.
