55 chevy pickup Emergency Brake
Discussion in 'The Hokey Ass Message Board' started by ysmitty, Oct 17, 2009.
  1. ysmitty
    ysmitty
    from mass
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8"><meta name="ProgId" content="Word.Document"><meta name="Generator" content="Microsoft Word 9"><meta name="Originator" content="Microsoft Word 9"><link rel="File-List" href="file:///C:/Users/bob/AppData/Local/Temp/msoclip1/01/clip_filelist.xml"><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:DoNotOptimizeForBrowser/> </w:WordDocument> </xml><![endif]--><style> <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style><!--[if gte mso 9]><xml> <o:shapedefaults v:ext="edit" spidmax="1026"/> </xml><![endif]--><!--[if gte mso 9]><xml> <o:shapelayout v:ext="edit"> <o:idmap v:ext="edit" data="1"/> </o:shapelayout></xml><![endif]--> Hi,
    <!--[if !supportEmptyParas]--> <!--[endif]--><o:p></o:p>
    I am hoping that someone has had this problem before so I don't have to re-invent the wheel, so to speak.
    I am trying to set up an emergency brake for my 55 Chevy pickup that has a Camaro clip and Camaro rear end. I am missing the original E-brake handle and the rods that attach to it. I have a foot pedal setup from a Chevy Lumina that I am going to use. Here is the question. What cables should I use on the rear axle? Should I use Camaro components or the original 55 Chevy truck stuff going from the rear axle to the lever that's mounted on the midpoint of the frame? If so will the 55 cables hook up to the backing plate and arm inside the brake drum?
    [FONT=&quot]Thanks[/FONT]
  2. squirrel
    is this a first or second series 55 truck? (does it look like a 47-54 or a 56-59?)
    anyways...usually it's a good idea to use the original stuff up to the equalizer (the bar in the middle of the truck), then you only have to make one new funky cable work
  3. ysmitty
    ysmitty
    from mass
    Hi Squirrel,
    It's a second series. Thanks for the tip. That does seem like the easiest way to go.
    Thanks
