Hot Rods 55 Chevy Project
Discussion in 'The Hokey Ass Message Board' started by Del Ray Dude, Sep 22, 2021.
  1. chevy57dude
    chevy57dude
    You can weigh it when you run at the track!
    Weight my 210 lost :
    Front bumper
    Front frame, A arm suspension, stock interior, br*** radiator
    Gains :
    Big block, with aluminum heads
    Blower & drive, 2nd carb 100 lb
    Sound deadener throughout, 100 lb
    Roll cage 100 ish pounds
    Horsepower wins races, but torque moves the car. That 455 has a 4.21'' stroke! Much longer arm than the Chevy 454. Top end package on that engine to wake it up and you'll be happy. Now about that rear...
  2. A 455 powered 55 will be cool, you should really look into a rear axle upgrade tho. 8.8 or 9' ford might be the best options. try trifive.com for more info.
  3. Del Ray Dude
    Del Ray Dude
    No question Scotty. Not sure what is under it now, but guessing OEM, and not sure what GM used with the original 265 cid motor. I'll have to check it out. Trim tag and VIN are no help. Also ***uming power glide was original trans? When I got the car, the original trans was replaced with a 3 speed manual behind a 327 (which I sold years ago). The previous owner hacked the body up pretty good putting it in. Thanks for the trifive.com tip.
  4. My experience with the 55-64 rear ends is the open ones are pretty weak and the posi’s are quite a bit stronger. But how long it will last depends on a lot of factors.
    Del Ray Dude and loudbang like this.
  5. Del Ray Dude
    Del Ray Dude
    Thanks Scotty. Going to attempt to post some photos. Like I said earlier on this thread, it's not pretty! LOL. Got my work cut out for me. Got all the front end sheet metal and trim. No interior. My starting point!
    tommyd, wheeldog57, scotty t and 7 others like this.
  6. chevy57dude
    chevy57dude
    Holy cow that car looks sold as a rock!
    Great starting point. Thought the bike was vintage for a second till I saw belt drive..
  7. guthriesmith
    guthriesmith
    Looks like a great start and will be cool with a Pontiac motor in it! Will be following along!
  8. Del Ray Dude
    Del Ray Dude
    Thanks guys. You haven't seen the floor pans though! Pretty bad shape. The good thing is, after market replacements seem to be readily available. I have been looking at Cl***ic Industries. Who do you guys use?
    BTW Scotty, the scooter is an '82 FLH (shovelhead). Had a side hack on it when I got it. It's a hoot to ride. It needs some work as well. Lot's to keep me busy!
    loudbang and scotty t like this.
  9. Del Ray Dude
    Del Ray Dude
    I probably should get on the trip-five forum
  10. I’m not active on there anymore but i do a cruise through fairly often. I go by “scotty t” on there too.
    loudbang and Del Ray Dude like this.
  11. chevy57dude
    chevy57dude
    The social forums will vanish soon. Hang out here on the main board, and check out the tri 5 threads. The one piece floor pan is the way to go if you have major brace/inner rocker damage.
    Otherwise get patch panels, cut out only the rusted area and section them in.
  12. ratfink56
    ratfink56
    If yer gonna go flat tappet cam do a bunch of reading.
    Buddy of mine who has been building racing engines for a loooong time just put a cam in his bbc. All the proper procedures and lubricants. Never made it past idle on break in and 13 lobes went flat. Cam company said too bad, musta done something wrong. Cam company rhymes with romp. Your mileage may vary.
    And welcome to the HAMB.
  13. -Brent-
    -Brent-
    The car doesn't look too bad. It sounds like a great combo.
    loudbang and chevy57dude like this.
