55 chevy starter wiring
Discussion in 'The Hokey Ass Message Board' started by championblythe, May 6, 2011.
  1. championblythe
    championblythe
    from Texas
    Anyone know what wire goes where
  2. handyandy289
    handyandy289
    from Georgia
  3. nwbhotrod
    nwbhotrod
    from wash state
    What wire where
  4. handyandy289
    handyandy289
    from Georgia
    Positive battery cable goes to large terminal bolt on solenoid. Wire from start terminal on ignition switch goes to small terminal on end of solenoid. (not to copper connection that goes into starter. Easy connections. Good luck
  5. 210sedan
    210sedan
    from upnorth,wi
    purple wire goes on small termial next to block,other one green? outside
  6. d2_willys
    d2_willys
    from Kansas
    S terminal = purple wire from neutral safety switch if automatic trans. From ignition start terminal for stick. R terminal = green wire from ignition coil + terminal or ballast resistor terminal from + of coil.
    There might be a 10 or 12 gauge wire that connects to the big terminal where the battery cable connects. This is for voltage regulator, horn relay, etc.
    Enough said, now go wiore it up!
  7. the chain should be bolted to the frame and long enough to reach the road to complete grounding
