55 chevy wiper transmission
Discussion in 'The Hokey Ass Message Board' started by chopped, Nov 11, 2013.
  1. chopped
    chopped
    When looking for another it seems they come in a left and a right. How do you tell them apart ? I have one but don't know which one. Thanks
  2. snaptwo
    snaptwo
    ,Those old cable drive setups are discussed over on trifive.com , lots of factory manual downloads .
  3. chopped
    chopped
  4. henryj1951
    henryj1951
    from USA
  5. Just Gary
    Just Gary
    The left wiper transmission has an "L" on the shaft. The right wiper transmission has an "R" on the shaft.
  6. 5559
    5559
    from tn
    see above + left trans part number will end with an odd number & rt side will be even
  7. 5559
    5559
    from tn
    also when installed the left side cables should cross each other to allow the left arm to park pointing in
  8. chopped
    chopped
    This is some great information, thanks.
  9. henryj1951
    henryj1951
    from USA
    whilst reading in the 1955 shop Manual...
    Body 1-3 and page body 1-4
    it says ...
    CAUTION: Cross right transmission drive cables and install
    to drum"A," install left transmission drive cables (not crossed) to drum "B"(fig. 3)
    yer left yer left yer left right left solder...
    its all good
    while looking under the dash... the drum closest to the firewall is drum A,
    the drum further away , or better said the inside one.
    The other one is drum B.
    :cool:
