55 Chrysler Windsot
Discussion in 'The Hokey Ass Message Board' started by JEP, Aug 22, 2013.
  1. JEP
    JEP
    from MD
    I have a 1955 Chrysler Windsor with a spitfire. Will a late model transmission bolt up behind it?
  2. Rusty O'Toole
    Rusty O'Toole
    No. What's wrong with the old one?
  3. mlagusis
    mlagusis
    My brother has a 56 New Yorker with a 354 and a turbo 350. Not sure if the adapter kit will work yours. A spitfire is the poly motor right?
  4. George
    George
    You'll need a 392 adaptor for what ever ****** you want to run. I like QEC's (73RR here) but TR Waters, Wilcap, & Hot Heads sell them.
  5. Rusty O'Toole
    Rusty O'Toole
    55 Windsor Spitfire is a poly version of the Chrysler hemi. Same block as the 55 hemi used with the Powerflite automatic (not the extended bell used with the 53 and earlier Fluid Drive).
  6. d2_willys
    d2_willys
    from Kansas
    A cast iron torqueflite should bolt up to it, but you will need come up with an adapter for the shift cable. Also, since the torqueflite is longer by an inch or so, the driveshaft may need to be cut.
  7. d2_willys
    d2_willys
    from Kansas
    Hotheads sells A727 torqueflite adapters too for the old hemi and 301 Polys.
  8. 31Dodger
    31Dodger
    A Spitfire could be a poly or a flathead.
  9. 302GMC
    302GMC
    from Idaho
    Not in 1955 it couldn't ...
