1952-59 Ford '55 door not latching...
Discussion in 'Off Topic Hot Rods & Customs' started by Mr. Tomato Head, Feb 17, 2021.
Tags:
  1. Mr. Tomato Head
    Mr. Tomato Head
    Hey guys. Doing my monthly Winter start up of "Sophie", my 1955 Ford Country Sedan wagon and discovered the front p***enger-side door is not latching. (Doesn't stay closed) I turned the star-shaped gear (see picture) with my hand and noticed that it doesn't catch/stop. Is this a big job to fix?
    Thanks, Mato
  2. JeffB2
    JeffB2
    from Phoenix,AZ
  3. jimmy six
    jimmy six
    Not on a 55 but on a 56; the outer handle ****on was coming out to normal but the arm it was hitting operate it was not. I took off the door panel and the door handle and could see it thru the hole. I was able to free it up and lubricate it. Once it was free everything works fine. I left the handle off for a few days and continued to use a screw driver to push the arm to open the door. I also had to adjust the screw on the end of the ****on to make sure the ****on adjusting screw had a gap to know the latch would work. Hope this helps
  4. Mr. Tomato Head
    Mr. Tomato Head
    Thanks.
  5. danman55
    danman55
    Ray - got your message on my site, going to respond there since it is easier for me to load files and all...
  6. Mr. Tomato Head
    Mr. Tomato Head
    Got it! Thanks.
  7. JeffB2
    JeffB2
    from Phoenix,AZ
