1952-59 Ford 55 Door Removal
Discussion in 'Off Topic Hot Rods & Customs' started by TRoper, Dec 13, 2014.
  1. TRoper
    TRoper
    Hi People,
    Was just out trying to remove the doors from my 1955 Fairlane. Could not figure out how to disengage the door stopper. Is there a trick?
    Thanks
    Steve
  2. 55Brodie
    55Brodie
    You will need to cut the head off the pin. Replacements pins use a snap ring.
  3. Texas57
    Texas57
    I dunno, mine didn't have them, but if you haven't removed/loosened the door yet, drill a 1/8 hole thru the inner door panel into the hinges, for each hinge. Do the same at the hinge/doorpost. These will give you a real close alignment when you put it back together by using 1/8 pins/drill bit shafts in the holes before you snug the bolts.
