55 f100 gasser project
Discussion in 'The Hokey Ass Message Board' started by lilclay81, Dec 22, 2008.
  1. lilclay81
    lilclay81
    from illinois
    lookin for some help on how to llift the front end of my 55 f100 with the stock straight axle and stock steering setup tryn to set it up like an old g***er because i never seen one done like a g***er. but i tryn to stay away from using blocks under the springs if anyone has some advice would be greatly appreciated.
  2. Gearstix
    Gearstix
    I would like to do my truck up with a straight axle and leafs and stuff, but I think its a bit 'disrespectful' almost... its a '94
  3. The Big M
    The Big M
  4. lilclay81
    lilclay81
    from illinois
    thanks didnt think about that
  5. Gotgas
    Gotgas
    from DFW USA
    I think a stock '55 F100 is high enough without any additional lifting. How about a slight lowering of the rear end and a stock height nose?
  6. billsgarage83
    billsgarage83
    from NJ
    if you do an axle over in the rear and maybe take a few leafs out the front end will sit really high
  7. Loose the stock Cast axle and go to a Strait Tube axle. No need to re work the steering and would raise the Truck 3 or 4 inches, what ever the stock step is from spring pad to King pin boss. Plus it would look more correct.
    The Wizzard
  8. lilclay81
    lilclay81
    from illinois
    yea is there anyone out that makes tube style axles for a 55 f100 pickup
