Technical 55 fairlane headlights
Discussion in 'Traditional Customs' started by SnipeHunter, Apr 25, 2017.
Tags:
  1. SnipeHunter
    SnipeHunter
    from Omaha
    Looking to upgrade my headlights on my 55 Fairlane, car is converted to 12 volts, any ideas ?
    Thk
  2. F-ONE
    F-ONE
    from Alabama
    Sealed beam halogen works well. Standard 12V sealed beams work good too.
    porknbeaner likes this.
  3. SnipeHunter
    SnipeHunter
    from Omaha
    Thanks F-ONE, just looking for somthing thats a step up from stock, that will just replace originals.
  4. Sealed beam halogens are what I like, but if you want to spend the money Cibi makes a nice halogen conversion that has a convex lens instead of a flat lens.
    I usually just run halogen sealed beams.
  5. bobss396
    bobss396
    Halogen sealed beams are great, mine were less than $9 at Rock Auto and they are plenty bright.
  6. The Cibies will be better than halogen sealed beams by about the same amount that halogens are better than regular sealed beams.....
  7. squirrel
    The normal replacement H6024 you find at walmart for under ten bucks works fine for me...maybe I'm not as old as you? $80 a pop is a bit much...but I guess if you are into that sort of thing, go for it.
  8. Dry Lakes Racer
    Dry Lakes Racer
    from So Cal
    I use Halogens in my 56. Brighter but not real white or blue. If your still using a generator you don't want to go nutz here .
    I'm with Jim unless you are off road, on the desolate hyways of Montana, or the outback of Australia stock or Halogen are fine.
  9. Jim, I drive some pretty black roads; few or no street lights in places, trees overhanging so you don't always even get the moonlight, not to mention stormy overcast nights when it's really pitch-black outside. They're markedly better in the rain (a NW specialty, particularly this year!), but in any case still have more/better light over a 'standard' halogen. I've been running Cibies in the cars/motorcycles that I can since the early 70s (well before they were legal) and won't settle for less if I can help it....
    Precision optics and optical-quality gl*** does make a difference.
  10. squirrel
    Yeah, rain is a problem....the dark nights, we have plenty of here in the desert.
