1952-59 Ford 55 Ford brake lights not working
Discussion in 'Off Topic Hot Rods & Customs' started by Mr. Tomato Head, Aug 9, 2025.
Tags:
  1. Mr. Tomato Head
    Mr. Tomato Head
    Hey guys. The brake lights on my 55 Ford Country Sedan recently stopped working. (I had to find out the hard way with a guy pulling up next to me and bringing it to my attention.) The taillights are getting power. I cleaned the connections on the two plugs connected to the switch attached to the master cylinder. Still nothing. I traced wiring under the carpeting as far as I could. It seems fine. The wiring in the tailgate seems okay as well. Thoughts?
  2. Adriatic Machine
    Adriatic Machine
    Are the light fixtures grounded to the body? I would remove them and ensure you’re getting a good ground. Also consider running a dedicated ground wire.
    down-the-road likes this.
  3. Mr. Tomato Head
    Mr. Tomato Head
    I think it's the brake light switch. Ordering a new one on Monday. Thanks guys.
    Adriatic Machine likes this.
  4. jimmy six
    jimmy six
    Brake light switch on the master cylinder……. Get one from a Harley Davidson dealership. Best ones out there !
    bobss396 likes this.
  5. bobss396
    bobss396
    I found a good one on eBay, trips at 25 psi. I have a spare in the glove box.
  6. JeffB2
    JeffB2
    from Phoenix,AZ
    If you still have the original master cylinder those are prone to failing, some guys convert those to something like this, it is a GM switch with a homemade bracket has been done often. donkey.jpeg
    ottersea, bobss396 and nosford like this.
  7. Paul2748
    Paul2748
    On my 54, I converted to n electric switch. This is the best thing.. If adjusted right, instant brake light when you touch the pedal to warn the other drivers.
    JeffB2 and down-the-road like this.
