Technical 55 Ford Steering Too Sensitive
Discussion in 'The Hokey Ass Message Board' started by FatfenderJ, Mar 7, 2026 at 7:56 AM.
  1. FatfenderJ
    FatfenderJ
    I recently purchased a 55 fairlane wagon. It is stock other than wheels and a disk brake conversion. It's a y block with power steering. The power steering is VERY sensitive. If I drive with more than 2 fingers it darts and feels like I will run off the road. Ideas on what's wrong? I've done a search and haven't come up with much.
  2. BJR
    BJR
    Have you had the front end aligned?
  3. garyf
    garyf
    Checked if that frame cross member in front isn't rotted or replaced and hacked ?
  4. AldeanFan
    AldeanFan
    Start by checking that all the suspension and steering components are tight and in good condition. You can do anything if you’ve got worn out bushings or tie rods.
    Next get an alignment from a shop that knows what they’re doing. Find the grumpiest old guy you can.
    next, what tires are you using and what air pressure?
  5. earlymopar
    earlymopar
    Has the original power steering pump been replaced with an aftermarket pump?
