'55 Gasser Pix
Discussion in 'The Hokey Ass Message Board' started by nokmuay, Jun 21, 2010.
  1. nokmuay
    nokmuay
    from new jersey
    Thanks for the positive response. hello to you Gary. People asked for more pix, here are some.
    Since getting the g***er i had it painted, new straight axle ***embly, vega steering box, 427 cu. in. small block, world block, reworked brodix heads and manifold, callie crank, oliver rods, 12.5 comp pistons, jesel open timimg belt, and jesel rocker arm ***embly. solid roller with 4/7 swap, quick fuel special built 980 carb. 456 ford 9 in. rear, strange 33 spline axles. 3 point roll bar, moon tank. Coan turbo 400 with reverse pattern, manual valve body, trans brake, line lock.
  2. speedtool
    speedtool
  3. senior fried
    senior fried
    Very nice, glad you checked clearance, it surprises me how many guys don't. I would be curious how that carb works for you.
  4. nokmuay
    nokmuay
    from new jersey
    when we dynoed the engine we started with another racing carb, same size, just to get a base number, we did 3 pulls and then changed to the quickfuel card and gained 7hp, we were all very surprised but when qf built the carb they said it should perform like that. the car is street driven and the carb runs great.
  5. jason65
    jason65
    Sweeet. Awsome project.
