Technical 55 gasser
Discussion in 'The Hokey Ass Message Board' started by Rafaratrod1, Oct 29, 2015.
  1. Rafaratrod1
    Rafaratrod1
    Just bought a 55 Chevy wanna go g***er need and info n pics on how to do a straight axle build using a 55 truck axle , also what steering box would I use thanks
  2. Box is easy, *truck axle truck box as far as installation just search straight axle on here. It may not get you 55 truck specifically but it will get you enough information to figure it out.
    here is a pic of a setup like you have described unless you go full box frame stub like is popular with the newstalgia crowd.
    *the 55 car box will probably also work if you go cross steer.
  3. Rafaratrod1
    Rafaratrod1
    Thanks looks nice
  4. LOL its pretty shade tree but that is how it used to get done for the most part.
    There were actually way more independent front end five fives raced then straight axle cars, they were not hard to lift.
  5. traffic61
    traffic61
    from Owasso, OK
    Take a look at Road Farmer's '55 build, I think he is using a TF truck axle on that gorgeous piece of metal.
  6. Rafaratrod1
    Rafaratrod1
    Cool I'll check it out
  7. traffic61
    traffic61
    from Owasso, OK
  8. JOECOOL
    JOECOOL
    You can go to the Tri-Five Chevy forum also, a separate section on g***ers, dozens of builds using Chevy pickup axles. Best of luck
  9. fast30coupe
    fast30coupe
    from Illinois
    You can use the stock box I did worked good and kept things simple.
    Sorry for the bad picture I just put bungs in the stock location where i boxed it
    Depending on your motor location you might need to notch the oil pan.
  10. Preacher
    Preacher
    any updates on this build?
  11. Rafaratrod1
    Rafaratrod1
    Not yet rounding parts
