Projects 55 GMC engine ID
Discussion in 'The Hokey Ass Message Board' started by F8TL, Apr 25, 2021.
  1. F8TL
    F8TL
    Need some help with the iden***y of a straight 6 that is in what I was told is a 55 3100 frame. It is a short wheelbase frame and is a GMC block. I don’t know anything about these other than they liked to eat a lot of gas but were torquing things. Thank you for any help.
    IMG_2154.JPG IMG_2155.JPG IMG_2156.JPG IMG_2157.JPG IMG_2158.JPG IMG_2159.JPG
    Hnstray likes this.
  2. jimmy six
    jimmy six
    Tag says it’s a 248” but looking at the flat spot where the distributor goes will prove it with the first 3 numbers. The shorter stroke crank is good if it had 6 bolts which a 55 should have with a hydramatic. Tin work is all the same for 228-302’s. Head will be a small intake port open chamber, possibly the smaller chamber if not cracked sellable, along with the hydramatic. The smaller chamber head on a 270 is great on the street with the right intake and port/valve work.
    loudbang and Hnstray like this.
  3. F8TL
    F8TL
    Stamp at the distributor is 248 also.
    Thank you for the help.
  4. 56sedandelivery
    56sedandelivery
    And, there's a Hydro behind it. I am Butch/56sedandelivery.
  5. F8TL
    F8TL
  6. squirrel
    3100 is a chevy truck model number, and that's a GMC frame...the front crossmember is different than the Chevy version.
    Hnstray likes this.
  7. 302GMC
    302GMC
    from Idaho
    Don't let that starter get away ...
    jimmy six likes this.
  8. Stovebolt
    Stovebolt
    I would really like to run a Hydro transmission of a hot rod, but being that any hot rod I would build has to be right hand drive in order to get registered out here, the starter solenoid would be right in the way of the either the steering column, the brake and clutch pedals, or both :mad:
  9. jimmy six
    jimmy six
    It is GOLD....
    Tman likes this.
