1952-59 Ford 55 hard top frame supports
Discussion in 'Off Topic Hot Rods & Customs' started by brassspike, Dec 17, 2022.
  1. brassspike
    brassspike
    Anybody know how thick the steel was on these?
    Thanks!
  2. jimmy six
    jimmy six
    Do you mean the A and C pillers?
  3. okiedokie
    okiedokie
    from Ok
    I onder if they are referring to the steel plate welded to the bottom of the frame rails on some 55's. None on my 55 Sunliner.
  4. brassspike
    brassspike
    Yep, that's the one. I want to stiffen this thing up some. I had one here but didn't measure the thickness. I just didn't think to do that at the time.
  5. KULTULZ
    KULTULZ
    Can someone explain or show a photo of this plate? About where is it located? Was it an attempt at frame repair?
  6. okiedokie
    okiedokie
    from Ok
    I kind of think that maybe they were only on conv frames. Plates welded to the bottom of the X member from the factory. My Sunliner does not have them but I have seen pictures of the plates.
  7. Dos Cincos
    Dos Cincos
  8. okiedokie
    okiedokie
    from Ok
    No, these were plates added to the bottom of the frame rails and as I recall, I only saw pictures of convertible frames. When I started on my 55 I found those photos but can't now.
  9. Alan Freeman
    Alan Freeman
    I have a '54 Convertible, a '54 Skyliner Hardtop and a '54 Mainline Sedan and only the convertible has the steel plates welded to the bottom of the frame rails, obviously to stiffen the frame. If somebody needs to know the thickness of those steel plates I can measure them.
  10. jimmy six
    jimmy six
    I finally got curious and looked at my 56 Victoria. There is a frame plate that starts at 3” behind the body mount at the fire wall and ends infront of the body mount infront of the rear spring front mount. It is 1/4” thick and s***ch welded approximately every 6”. The welds are between 1” and 1-1”2” long. It is flat and turns up near the front. The 56 frame that dos cincos shows is what I have.
    No wonder theses cars were so good on the dirt tracks in the late 50’s on.
    down-the-road and Dos Cincos like this.
  11. brassspike
    brassspike
    Yes, that's it! I've added a lot of power and torque and would like to stiffen the frame. It would be great if you could give me the thickness!!
  12. brassspike
    brassspike
    Yes, please! Duplicating on my sedan.
  13. Alan Freeman
    Alan Freeman
    The measurements are pretty much as stated by Jimmy Six 1/4" thick plate.
  14. brassspike
    brassspike
    I thought it was a bit thicker but it's been a long time since I had the car. Never throw anything away!
    Thanks! Bill
