Technical 55 Merc Y block clutch Z bar bracket question
Discussion in 'The Hokey Ass Message Board' started by no55mad, Jun 15, 2024.
  1. no55mad
    no55mad
    Hello. Does anyone know if the clutch linkage on a 55 Merc is different than the 55 Ford. The Merc has a tubular Z bar. Trying to find the bracket that bolts to the block that interfaces with the Z bar. From online pics it looks like the Merc has a shaft on the motor bracket and a clam shell pivot ball fits on the shaft and goes into the end of the Z bar. Any Y block gurus here that are acquainted with this clutch linkage? Thanks
  2. miker98038
    miker98038
    Sounds like the z bar on my 55 bird, but it’s been a while since I’ve had it apart. Post the picture you’ve found.
  3. famdoc3
    famdoc3
    It is like the bracket on my 57 T’bird. Doubt Ford did a lot of different ones. T’bird suppliers will have them.
  4. no55mad
    no55mad
    Not that techy so can't get the picture posted. There is a site online that has the whole service manual for the 55 Merc and the diagram of the clutch linkage is around page 120. From looking online it seems the 55 Ford linkage may be different. The Merc has a tubular z bar and the Ford bars seem to be from flat stock.
  5. JohnLewis
    JohnLewis
  6. no55mad
    no55mad
    Page 191 item 77505 in the 55 Merc ch***is book. That is the bracket that interfaces with the z bar. The z bar on page 190 is different than the z bar on page 191. The 55 Merc has the tubeular z bar. Now to hopefully be able to find that bracket and clamshell bearing that goes into the z bar. Maybe the Thunderbird is similar.
