Projects 55 Olds suspension
Discussion in 'Traditional Customs' started by kosnmotion, Jan 29, 2025.
  1. kosnmotion
    kosnmotion
    from Phoenix
    Anyone know where I can get front 3" lowering springs for 55 Olds?
  2. Bird man
    Bird man
    from Milwaukee
    Not hard to cut some coils but that is pretty low. Let me check the Hollander book for spindle interchange.
  3. kosnmotion
    kosnmotion
    from Phoenix
    Yeah I didn't really want to cut them. You used to be able to get them from Jamco but it seems they went under or someone bought them out. If that's the last resort I will though
  4. 60 Special
    60 Special
    from Omaha Ne.
    You can try Coil Spring Specialties in St. Mary's Kansas. They have a website and cater to the cl***ic vehicle market. 60 Special
  5. You could measure your springs and find another application that would fit.
    bobss396 likes this.
  6. bobss396
    bobss396
    There is an online Moog catalog That will be a big help.
  7. In_The_Pink
    In_The_Pink
  8. 57JoeFoMoPar
    57JoeFoMoPar
    You could use a dropped coil, but you can also drop the lower control arm to lower the car. The 55 Olds uses a heavy C-channel control arm with the stamped spring pocket riveted in. If you cut/drill out the rivets, you can add a spacer between the spring pocket and the control arm and replace the rivets with bolts. This will give you a similar dropped effect, and will allow you to lower the car without chopping the coil substantially.
    bobss396, Paul and TrailerTrashToo like this.
  9. kosnmotion
    kosnmotion
    from Phoenix
    Cool Joe, thank you
    sdluck likes this.
  10. Paul
    Paul
    Editor
    I did that very thing on a '56
    I used a 1"x1" solid aluminum bar
    I don't remember exactly how much it lowered it but it must have been about 2" measured at the front bumper.
    57JoeFoMoPar and sdluck like this.
  11. Gahrajmahal
    Gahrajmahal
    My family had a 55 Olds 88 like this one, but a four door. I was brought home from the hospital in that car and we had it for 27 years.
  12. tubman
    tubman
    I would think a combination of the spacers and a smaller coil cut might be the answer.
  13. Have you tried AFCO?
    https://www.afcoracing.com/
