Projects 55 Pontiac 2dr HT Stocker to Mild Custom Build, More Updates!
Discussion in 'Traditional Customs' started by Toast, Jan 13, 2014.
  1. 1951Streamliner
    1951Streamliner
    from Reno, NV
    I'm glad to hear it!
    Can't wait to see it.
  2. Love it. Had one back in the day, blue where your's is green, column 3 spd. Put a '57 engine in it and it was pretty quick. First car I raced at a real drag strip.
  3. Toast
    Toast
    from Jenks, OK
    Thanks, I have a fresh 56 316 I will be putting in the car in the near future.
  4. sololobo
    sololobo
    Dude, you read my mind, did what I would have. Beautiful car bro, congrats. One of the coolest factory customs ever.
    dude, you read my mind. You did what I would do, super sweet ride, congrats.~sololobo~
  5. Toast
    Toast
    from Jenks, OK
    Front end is down 2 1/2" now looking soooo much better. still needs aligned.
  6. robertsregal
    robertsregal
    Killer, Great lookin car like it all!!!!
  7. Toast
    Toast
    from Jenks, OK
    I also have a set of stainless skirts and trim like in the pic below that I am planning on putting on.
  8. Toast
    Toast
    from Jenks, OK
    Here is a better shot of it outside, still needing alignment. Good think I opted for new tires cause the L78's will NOT come off the back with it lowered. Going to have to take the blocks off to get the tires off. That would have been fun on the road!:eek: Hopefully the new narrower shorter tires will be easier to change out.
  9. barryvanhook
    barryvanhook
    from Mesa, AZ
    Nice ride; nice job!
  10. oH weLL heLL
    oH weLL heLL
    from SOKAL
    Good looking '55. Stainless panels will def add to the looks. Later.
  11. 55chieftain
    55chieftain
    Cars looking great. I ended up getting some longer shocks in the back of mine so the rear end drops down further when jacked up from the frame to get the tires on/off. I don't have to worry about it now though with the 1/4's radiused. I had a rear end that was a inch narrower and 235/60 15 on a 7" wheel and no problems getting them on and off. But that was without lowering blocks also.
  12. kippers 34
    kippers 34
    I unbolt the shock from the lower mount before I jack the car up this allows the rear end to drop a little further. I still can barley squeeze the tire in.
  13. wreckfixer
    wreckfixer
    That's one good lookin' Poncho!
  14. Jay71
    Jay71
    I really dig this 55. Like what you have planned for it too.
  15. Toast
    Toast
    from Jenks, OK
    Thanks guys, I hope to have it done by next weekend at least mostly. Just waiting on brake parts and tires. Will post updated pics as it evolves.
  16. pammiesuesguy
    pammiesuesguy
    Very nice Chieftain hardtop. I own 3 of these cars and those full disc hubcaps like to slide on the rim when braking hard and pinch the valve stem. I finally put dog dishes on with beauty rims and wide whites.
    Rich
  17. Blk210
    Blk210
    from New Market
    I put a bar in the shackle and pull down so it arches the spring fully and am able to wiggle my 275/60r15 out, I have g78 wide whites and there a breeze to remove with this method but I have rolled the inside lip so it's rounded.
  18. 1951Streamliner
    1951Streamliner
    from Reno, NV
    Stance is perfect.
    Cant wait to see the new tires.
  19. Toast
    Toast
    from Jenks, OK
    Wow! Really! Guess I will have to keep my eye on them.
  20. 1951Streamliner
    1951Streamliner
    from Reno, NV
    I've heard that putting a strip of ductape along the surface where the teeth grab onto the wheel will prevent any movement and wont let the cap fly off.
    May be worth a try if you're concerned about it.
  21. there's all kinda tips and tricks to solving that. its a pretty widespread problem, a quick search on the net will give you hundreds of different tips and tricks for it
  22. Toast
    Toast
    from Jenks, OK
    Here is some new additions. the original air cleaner bottom was finished at the chrome shop today, so we did a test fit with the striped by Chaddilac lid and the new finned covers. Big improvement! While messing with that stuff, noticed that the water pump was leaking, so yet another setback:(
  23. Toast
    Toast
    from Jenks, OK
    Also got the new tires on the car. Stance looks great, need to align it and trim the new rear bump stops for max travel and the big part will be done!
  24. SuRfAcE_RuSt
    SuRfAcE_RuSt
    Ditto on that.
    Sometimes you even have to let the air out of the tire. :D
  25. kool! and dont worry about the water pump, just have a guy sitting on your hood pouring water into your engine as you drive:D
  26. chaddilac
    chaddilac
    DANG!!! that's low!!!!
  27. Toast
    Toast
    from Jenks, OK
    Its supposed to be! :D
  28. 1951Streamliner
    1951Streamliner
    from Reno, NV
    Very nice.
    Cant wait to see it outside.
  29. SoCal
    SoCal
