55 pontiac question
Discussion in 'The Hokey Ass Message Board' started by slammedchieftan, Jan 18, 2009.
  1. slammedchieftan
    slammedchieftan
    Does anyone know what the original front end hub to hub width on a 55 pontiac chieftan is?
  2. Mule Farmer
    Mule Farmer
    from Holland MI
  3. 55chieftain
    55chieftain
    IIRC about 59-60". You clipping this thing or what?
  4. slammedchieftan
    slammedchieftan
    IIRC? Ok heres the deal, My stock rear end is 60 5/16 and if the front is around 60" as well. I ordered a fat man stub for it, and it comes 58 1/4 wide hub to hub, I have a rear end I want to use that is 59 3/4 ( ford 8.8 ) is it going to be a big deal for the rear to be 1 1/2 wider? Do I have to use rear wheels with different back spacing? I guess I'm thinking the front and rear tires should measure the same outside to outside. Am I off base for thinking this?
  5. 55chieftain
    55chieftain
    It would be ok to use a little wider track in the rear. Watch your backspacing in the rear, too much and it will get into the leaf spring, get the rear end bolted in than measure clearance.
    IIRC- If I Remember Correctly.
