1952-59 Ford 56 a arm splash shields
Discussion in 'Off Topic Hot Rods & Customs' started by 56longroof, Nov 27, 2015.
  1. Rui
    Rui
    Mine were gone in some places. Staples where in place tough. Tough little guys. I removed everything and called it done.
  2. bobss396
    bobss396
    And really, how well are those staples going to hold? Not very well.
  3. buymeamerc
    buymeamerc
    from s.c.,usa
    grainger has rubber sheets, multiple thicknesses also
  4. 56longroof
    56longroof
    I wouldn't mind trying my hand at making a set but without a template it will be hard to get the size right. Plus I still have to find a retainer.
  5. Jimmy2car
    Jimmy2car
    from No. Cal
    Also, to add to Buyme's post, Home Depot & Loews have rubber sheet goods in the flooring depts that I think will work well.
    I'm also thinking about trying to make retainers from sheetmetal stock. Can't be too hard and would look very close to original, after painting?
    Texas57 likes this.
  6. Jimmy2car
    Jimmy2car
    from No. Cal
    That RCB973 is not only high priced, but his shipping charges are outrageous
  7. 56longroof
    56longroof
    Anyone have a set laying around they want to part with?
  8. HOTRODPRIMER
    HOTRODPRIMER
    Get in touch with FLAT-TOP BOB at www.owenssalvage.com
    With over a hundred acres of early cars I'm sure he can help you with what you need,Bob has always came through with the parts I needed. HRP
  9. 56longroof
    56longroof
  10. 55Brodie
    55Brodie
    Roof,
    here are the part numbers that might help:
    B5A-16050-A (RH) and B5A-16051-A (LH) retainers
    B5A-16240-A seals
  11. 56longroof
    56longroof
    I found a set of repro's but didn't want to pay the $100 for them. I tried Owens 3 times and keep getting the run around. I may look around at different salvage yards. I was hoping to have a set by now because I am done painting the suspension components and am going to start on the engine bay.
  12. chopd top
    chopd top
    from Florida
    Just go ahead, bite the bullet and make a set. It really doesn't look that tough to do. I know you could do it a lot cheaper than the $100 for the repops.
  13. Paul2748
    Paul2748
    You can buy the staples. I know that CASCO, the TBird parts house, has them. I have bought them.
    I have also made my own out of stainless wire. You just have to bend them to the correct width - measure the distance between holes. They are all the same.
  14. 55Brodie
    55Brodie
    Paul,
    I think the hangup is the sheet metal retainers.
  15. 56longroof
    56longroof
    Yep the sheet metal retainers. I may try to mock up a cardboard template and see how it looks.
