1952-59 Ford 56 brake line kit
Discussion in 'Off Topic Hot Rods & Customs' started by 56longroof, Dec 3, 2015.
  1. 56longroof
    56longroof
    I am getting ready to buy a brake line kit for my wagon but it seems all the ones I have found are for 4 doors. Do you think a 2 door car set would work on my Ranch Wagon? I think the wheel base is the same and the only thing I can think of that is different is the rear axle which shouldn't pose a problem.
  2. leadsledjim
    leadsledjim
    from Iowa
    I am about to do the Brakes on my 53 ford.
    Planning on going to Auto Quest & Purchasing a 25 Foot Roll of Brake Line.
    Part Number CNC-325
    Easy to Bend & Flare. Will Not Rust!
    Can Be Painted with Aluminum Paint where you See it for Looks.
    Buy New Fittings for a Complete Job.
  3. bobss396
    bobss396
    I think the 4-door kit would work. At the worst you'd have to deal with the one line that runs the length of the car.
  4. Texas57
    Texas57
    I had originally ordered a full ss set from inline tube. I was more than a little surprised at the quick delivery since they are all made to order(shipped out the next day!), but i was particularly impressed with the quality. It was just a beautiful set of lines. As it turned out, I changed up so many things I couldn't use any of it forward of the firewall. I'd at least get a price from them to see what the current cost is.
    I'm with Bob, btw, can't see how a 4 dr would be different from a 2 dr.....'57's we do have 2 different wheelbases, but it's Custom vs. Fairlane, not anything else.
  5. JeffB2
    JeffB2
    from Phoenix,AZ
    This is for a Ford wagon: http://www.cl***ictube.com/catalogs...&box=&engine=&ymm_cat=Complete Brake Line Kit
  6. JeffB2
    JeffB2
    from Phoenix,AZ
  7. bobss396
    bobss396
    Nice that you can get all that stuff pre-made. Like Tex, my lines are all custom, north of the firewall.
  8. Texas57
    Texas57
    Aside from all the obvious advantages of going this route, you get all the little add-ons like protective sleeves and springs that you most likely wouldn't/couldn't do making the lines yourself. Not a whole lot of difference in $ from plain steel to stainless either in the kits. Big difference if your buying materials since the only "easy" way to fab with corrosion protection is the expensive NiCopp lines.
  9. 56longroof
    56longroof
    Did a little checking and according to Automobile Catalog the 2 door and 4 door are the same wheelbase. Surprised me a little bit. I would have bet the 4 door was longer. So I'm going to order a kit from Cl***ic Tube in stainless.
  10. JeffB2
    JeffB2
    from Phoenix,AZ
    Pictures of the product and install when you get them OK?
  11. 56longroof
    56longroof
    Will do. It will be a while. I've been slow on progress on this. I pulled the 6 cylinder and all the front suspension. Steering box comes out tomorrow and dropping the rear axle to pull the springs to put new bushings and pads between them. Oh and fixed the front crossmember. I may start a build thread soon.
  12. JeffB2
    JeffB2
    from Phoenix,AZ
    Looking forward to a build thread ;)
  13. bondojunkie
    bondojunkie
    Just recently received my lines from Inline Tube for my 59 and was very happy with the quality. As Bobss396 said, the one that runs from front to rear is a real bear to install! Never occurred to me that the lines are installed before the body is mounted.
  14. bobss396
    bobss396
    Yes, a nice GOTCHA....
    bondojunkie likes this.
