Technical 56 Buick Lifter Question
Discussion in 'The Hokey Ass Message Board' started by Sgt. John, May 27, 2017.
  1. Sgt. John
    Sgt. John
    from Virginia
    Hello folks got my new cam, lifters,push rods , timing set gaskets and ***embly lube BIG QUESTION DO I SOAK THE LIFTERS..... THEY HAVE BEEN IN OIL STANDING UP FOR 2 DAYS ... I heard some people do and some don't ..Did I screw up thanks
  2. 302GMC
    302GMC
    from Idaho
    What you want is camshaft break-in lube. It should come w/ the cam & lifters.
    You can "bleed'' the lifters submerged in oil if you want - doesn't actually make any difference.
  3. henryj1951
    henryj1951
    from USA
    To LATE now
  4. henryj1951
    henryj1951
    from USA
    to those who know what -n- how... its done.
  5. jimmy six
    jimmy six
    I always soak lifters whether hydraulic or solids. Makes it easier when spinning the oil pump to fill up every thing. I also stand the hollow push rods in oil too for the same reason.
    henryj1951 likes this.
  6. Sgt. John
    Sgt. John
    from Virginia
    thanks for your reply
  7. henryj1951
    henryj1951
    from USA
    -----And i NEVER do.
  8. BOBCRMAN
    BOBCRMAN
    from Holly
    Buick pushrods are solid, so no need to soak anything in oil.. Lube the ends and the pockets they set in, lube lifter sides and cam break in lube on the face and away you go.
    Hnstray likes this.
