1952-59 Ford 56 Carpet Questions
Discussion in 'Off Topic Hot Rods & Customs' started by Karfever, Jan 22, 2014.
  1. Karfever
    Karfever
    Re-doing some stuff on my 56 Styleline and have a few carpet related questions.
    1. Is it typical for the floor to be bare under the front seat?
    2. Does the accelerator pedal mount under or on top of the carpet? (where it bolts through the floor pan)
    3. Is there a specific aftermarket supplier that has cut/sewn carpet that covers from the toe board all the way under the rear cushion?
    Thanks in advance for the help
  2. leadsledjim
    leadsledjim
    from Iowa
    Most all cars have some jute padding, or cotton padding under the carpet.
    The Gas pedal should bolt through the Carpet. Get the carpet in place and use a awl to find the holes thru the carpet.
  3. Karfever
    Karfever
    Does anyone know of a supplier of a 'one piece' floor carpet?
  4. JeffB2
    JeffB2
    from Phoenix,AZ
  5. 52ragtop
    52ragtop
    from Nebraska
    Not wanting to hi jack the thread, but what is everyone's thoughts on the various sound deadening materiel for under the carpet?
  6. I used the foil backed bubble wrap stuff for duct work found at Lowes or Home depot. it's a lot cheaper than buying it from an automotive supplier and works great
  7. JeffB2
    JeffB2
    from Phoenix,AZ
  8. Zapato
    Zapato
    when you get ready to install that carpet pull it out of the box, unfold and if at all possible leave it out in the sun for a few hours, will make it a bit easier to work.
